Commander Riker Posted May 18, 2015 Author Report Share Posted May 18, 2015 Well, I'm not using the head unit to power any speakers. I picked up an Alpine UTE-52B... and it has 6 RCA outs. 4 will go to an MB Quart under the passenger seat... 600w. And 2 will go to the infinity bass link in the rear. I have yet to confirm... but I suspect the returns for some of the stock tweeters are located in the "A" connector at the amp. I will report back with the color coding of wiring and how I end up doing it. I'm running 4 Ohm MQ quart component speakers and tweeters, using the provided cross over. Link to comment Share on other sites More sharing options...
Commander Riker Posted May 23, 2015 Author Report Share Posted May 23, 2015 Update: So, my plans have gone a bit awry once I have learned both: how the stock wiring works, and just how little the space beneath our seats actually is. Basically there is no way I'm fitting my aftermarket amp under either the drive or passenger seat, as I keep them fully reclined and low as possible. The seat motor would contact the amp for sure. Also, I'm running new wiring for the tweeters to get them on their own channels from the crossover. Right now the plan is to run the amp in the back right corner of the wagon, and send 4 channels to 4 crossovers under the passenger seat. Link to comment Share on other sites More sharing options...
VolvoNor Posted May 23, 2015 Report Share Posted May 23, 2015 That actually sounds logical to do, I had been wondering if you could fit a decent sized amp under the seats, but your plan is better. I might have run new wires to all the speakers though, the original wiring is quite thin. Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 23, 2015 Report Share Posted May 23, 2015 Running new wire sounds good in theory,but have you looked into getting throughthe door connectors in these cars? Also keep in mind that all of the factoryspeakers are essentially mid-bass,mids and highs. None of them really needa huge capacity wire gauge to be effective.Save the big wire for your subs. Link to comment Share on other sites More sharing options...
VolvoNor Posted May 23, 2015 Report Share Posted May 23, 2015 have you looked into getting throughthe door connectors in these cars? Yes I have done so a couple of times. Link to comment Share on other sites More sharing options...
Piston Slapper Posted May 26, 2015 Report Share Posted May 26, 2015 Wonder if you could get two relatively flat two channel amps and put one under each front seat... Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 26, 2015 Report Share Posted May 26, 2015 Wonder if you could get two relatively flat two channel amps and put one under each front seat...Two problems...Rear seat passengers feet andthe driver's power seat controller. Link to comment Share on other sites More sharing options...
andyb5 Posted May 26, 2015 Report Share Posted May 26, 2015 Not sure if you guys have looked, but the newest class of car amps are quite compact. The Rockford Fosgate PBR-series amps are only 6.75" x 4.25" x 1.5" - that's a tiny amp, you could literally hide it anywhere in the car you wanted!Kenwood, Alpine, Pioneer, Kicker, they all have amps that are roughly the same size. Link to comment Share on other sites More sharing options...
