scgator62 Posted May 28, 2015 Report Share Posted May 28, 2015 Recently I had a puff of smoke appear from drivers side window, now none of the window or mirror controls work on either door. If I put the top down the windows work. No fuses under the hood are blown. Does anyone know how to fix this? I'm thinking a wire may have een affected but can't seem to locate or access at the location between door mount where it is mounted in rubber tube. Any insight would be appreciated, thanks. Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 28, 2015 Report Share Posted May 28, 2015 What year? Coupe or 'vert? Link to comment Share on other sites More sharing options...
scgator62 Posted May 30, 2015 Author Report Share Posted May 30, 2015 1999 convertible Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 30, 2015 Report Share Posted May 30, 2015 Check fuse 35 again. Leave the fuse in placeand use a meter to look for voltage coming inand leaving the fuse. You can do it easily withthe small metal tangs on top of the fuse. If it checks out, look for voltage at the switchon the brown/orange wire in position A2. If the power doesn't get that far, start followingthe wire back towards the fuse box. You may have a bad contact in the door connector. Link to comment Share on other sites More sharing options...
