mattsk8 Posted June 18, 2015 Report Share Posted June 18, 2015 As many of you know, I did a manual swap in my 99 V70r about 2 years ago. I would've posted in that thread but the search feature here doesn't seem to work, and I think that thread has been archived so I can't post in it anyhow. The transmission I used was a M66 out of a 2005 S40.This morning, I started the Volvo and backed out of my driveway. Put it in 1st gear and started heading up my road and it just went "clunk", and the car was in neutral. I can still easily shift through the gears. I would say something may have happened to the slave cylinder, but generally if that goes the clutch gets stuck engaged, rather than disengaged. With the engine running and without pressing the clutch, I can shift through all the gears (including reverse) and it does nothing; no grinding or anything. There were no issues at all leading up to this, it always worked great.Any ideas? Transmission failure? Link to comment Share on other sites More sharing options...
KlausC Posted June 18, 2015 Report Share Posted June 18, 2015 Verify that one of the axles did not pop out of the tranny. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted June 18, 2015 Report Share Posted June 18, 2015 Verify that one of the axles did not pop out of the tranny. If both axles are there it could be the gear selector which a few people have had issue with Link to comment Share on other sites More sharing options...
mattsk8 Posted June 18, 2015 Author Report Share Posted June 18, 2015 I'll post back after I get home tonight and look it over. IMO, I think it's internal in the transmission. If it were a linkage issue, I think I would've had some sloppy feeling somewhere while shifting, but it shifts through the gears normally. It could be an axle issue, but I would guess there would've been some additional clunking or grinding if that were the case from the axle flopping around. Plus the fact that I can shift through the gears with the engine running and the clutch pedal out and not have it grind or do anything... makes me think something broke in the transmission. Either way... Volvos are dumb Link to comment Share on other sites More sharing options...
98glt-5 Posted June 19, 2015 Report Share Posted June 19, 2015 I put an aftermarket axle in my car. Was good for about 2 weeks, shifted second hard, and pop, no gears. Did exactly everything yours did. Broke the end of the axle off in the differential. Was like a bad clutch, could move shifter into every gear with clutch engaged and disengaged and engine running. Definitely check the axles. Put it up in the air, and spin an axle in gear, it should spin the other backwards. Link to comment Share on other sites More sharing options...
mattsk8 Posted June 19, 2015 Author Report Share Posted June 19, 2015 I put an aftermarket axle in my car. Was good for about 2 weeks, shifted second hard, and pop, no gears. Did exactly everything yours did. Broke the end of the axle off in the differential. Was like a bad clutch, could move shifter into every gear with clutch engaged and disengaged and engine running. Definitely check the axles. Put it up in the air, and spin an axle in gear, it should spin the other backwards.Thank you, I'll check this tonight. Link to comment Share on other sites More sharing options...
mattsk8 Posted June 19, 2015 Author Report Share Posted June 19, 2015 Pretty sure it's the driver's side axle, I'm going to take it apart later tonight. Any surprises you ran into when you took yours out? Only asking cuz that axle was a mofo to get out originally, I can only imagine it'll be worse now that I don't have the rest of the axle to pry on. Link to comment Share on other sites More sharing options...
mattsk8 Posted June 20, 2015 Author Report Share Posted June 20, 2015 Got the axle out and that was the problem, any ideas on how to get the broken part out of the transmission? Link to comment Share on other sites More sharing options...
Fran9690 Posted June 21, 2015 Report Share Posted June 21, 2015 Drill a hole in the broken piece and thread in a screw and pull out with a slide hammer. Link to comment Share on other sites More sharing options...
mattsk8 Posted June 23, 2015 Author Report Share Posted June 23, 2015 Drill a hole in the broken piece and thread in a screw and pull out with a slide hammer.Just spent $38 on a couple drill bits and some 1/2" threaded rod. I'm going to drill it, tap it, then thread the rod in through a big washer and tighten it until it hopefully pops out. Been busy, but tonight I'll get after it. Link to comment Share on other sites More sharing options...
mattsk8 Posted June 24, 2015 Author Report Share Posted June 24, 2015 The threaded rod worked well, broken piece is out. Going to get the new axle tomorrow and put it back together. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted June 24, 2015 Report Share Posted June 24, 2015 I bought a 1989 Taurus SHO in 2001 with a "bad transmission" like you thought you had for $350. put a $75 axle in and it was all good. splines had stripped. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted June 24, 2015 Report Share Posted June 24, 2015 I bought a 1989 Taurus SHO in 2001 with a "bad transmission" like you thought you had for $350. put a $75 axle in and it was all good. splines had stripped.The fact that you had an 89 SHO in 2001 just seems so fitting of you, I love it Link to comment Share on other sites More sharing options...
mattsk8 Posted June 24, 2015 Author Report Share Posted June 24, 2015 I bought a 1989 Taurus SHO in 2001 with a "bad transmission" like you thought you had for $350. put a $75 axle in and it was all good. splines had stripped.Nice. I've done this to the front driveshaft in my old Chevy 4x4 a couple times, but haven't seen a break like this on a CV axle before. Would've been tricky to find too, 98glt-5 was the reason I looked (thanks BTW). If he didn't post I'd have probably about had the engine cradle out before I realized the axle was the problem. It didn't make any noise at all except the one clunk it made when it broke.Raxles no longer supplies axles for Volvo, so I ordered a reman from Napa for $63. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted June 24, 2015 Report Share Posted June 24, 2015 The fact that you had an 89 SHO in 2001 just seems so fitting of you, I love itI had 3 SHOs in 2001. 2 89s and a 92. The 92 was supercharged. It was fucking fast. Had a quaife diff too. Link to comment Share on other sites More sharing options...
