Seaway Posted August 10, 2015 Report Share Posted August 10, 2015 When I got my car there was no hood insulation pad. I didn't mind the noise at first, but I would like to try and quiet it down some, if possible. Are there any products that work better than the stock hood pad? Dynamat? When I apply it, do I put it inside all the bracing that is in the hood? Cut to fit the openings, or should it cover everything? Will dynamat or similar stand up to the heat? Link to comment Share on other sites More sharing options...
loseR99 Posted August 10, 2015 Report Share Posted August 10, 2015 boom mat is what i used. got it from summit racing. Also works well to isolate noise in other places like door panels and such. Link to comment Share on other sites More sharing options...
Saleen9091 Posted August 10, 2015 Report Share Posted August 10, 2015 If you use it, I would just cover the whole thing. If you google it, you can see people do both methods. I would think for best results you would want to cover everything. I have used dynamat in the past and it uses some type of tack or tar to adhere. I have seen people use it for under hood applications so you should be fine. Link to comment Share on other sites More sharing options...
Seaway Posted August 10, 2015 Author Report Share Posted August 10, 2015 Thanks very much! I will try the boom mat stuff as it seems to be priced pretty well. Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 11, 2015 Report Share Posted August 11, 2015 Be careful about weight - OEM pad weighs nothing.If you use Dynamat or anything else heavy, the hood won't stay up. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted August 11, 2015 Report Share Posted August 11, 2015 Why not just go to the junkyard and grab one? Link to comment Share on other sites More sharing options...
Seaway Posted August 11, 2015 Author Report Share Posted August 11, 2015 Where I live there aren't really any junkyards, so just going to the junkyard and grabbing one isn't an easy option. The Dynamat and Boom Mat hood insulation weigh under 3 pounds, so I don't imagine the hood staying open would be an issue with either of those products. I may do nothing at all as I am not overly confident it will help with noise reduction anyway. Link to comment Share on other sites More sharing options...
tuner4life Posted August 11, 2015 Report Share Posted August 11, 2015 Not sure if they still do, but iirc Dynamat used to make a kit specifically for under-hood applications. Would probably look nicer than the stock piece too. Link to comment Share on other sites More sharing options...
