Jeph430 Posted August 19, 2015 Report Share Posted August 19, 2015 '01 C70 with the 5.1. I'm searching for a decent double DIN unit with Bluetooth that I won't lose this speaker but getting rid of my stock HU. Any suggestions? Thanks! Link to comment Share on other sites More sharing options...
Jeph430 Posted September 12, 2015 Author Report Share Posted September 12, 2015 So, doesn't exist? Link to comment Share on other sites More sharing options...
tuner4life Posted September 14, 2015 Report Share Posted September 14, 2015 Every aftermarket head unit I've seen doesn't use the center.. I'm sure there is some very expensive option that you could find that would use it, but most audiophiles I've talked to say that the sound quality is actually better without it. Link to comment Share on other sites More sharing options...
andyb5 Posted September 14, 2015 Report Share Posted September 14, 2015 Kenwood has included 5.1 processing on their higher-end double-din headunits for a long time. It would be possible to find a used one for a couple hundred dollars. Link to comment Share on other sites More sharing options...
Burn-E Posted September 14, 2015 Report Share Posted September 14, 2015 Jeff, last I recall, and I believe the post in the thread I'll link below confirms it, the configuration of the SC-901 is what drives the center speaker (internal matched amp + attached dolby processor) and I was under the impression that you would have to swap out the speaker if you wanted to keep a center channel. But further reading shows it would be possible to use the speaker you just might have some wiring to do. Not sure if it will preserve the Pro Logic sound though. And Steve would tell you that you'll get better sound if you went a different direction with speakers any way. I prefer sticking to stock with an adapter attached for iPhone connection.http://webcache.googleusercontent.com/search?q=cache:fe6Gy4gWfdcJ:volvospeed.com/vs_forum/topic/100848-replacing-sc901-with-aftermarket-hu-in-volvo-c70/+&cd=4&hl=en&ct=clnk&gl=ushttp://webcache.googleusercontent.com/search?q=cache:8vKqEa2U1KEJ:volvospeed.com/vs_forum/topic/162785-99-c70-coupe-aftermarket-head-unit-questions/+&cd=12&hl=en&ct=clnk&gl=ushttp://webcache.googleusercontent.com/search?q=cache:Bwg6YpfT-0gJ:volvospeed.com/vs_forum/topic/140367-pin-layout-and-power-2-way-center-channel/+&cd=17&hl=en&ct=clnk&gl=usDoing the webcache thing because historical and useful content has yet again been #$%&'d up by a site upgrade Link to comment Share on other sites More sharing options...
