RussB Posted August 29, 2015 Report Share Posted August 29, 2015 The engine is a 2.4L out of a 2000 V70 R,...Ignition is stock and I was told the plugs, rotor, cap and wires were replaced at about 175k. Don't the '99 and '00 have coil packs instead of the wires/cap/rotor, along with an ETM ?? Link to comment Share on other sites More sharing options...
Seaway Posted August 29, 2015 Author Report Share Posted August 29, 2015 Yes, but it is running the ecu and auxiliaries from a 1998. Basically the VVT is disabled, the distributor is added and it is then run as a 1998. It still has a throttle cable like a 1998. I may have now told you more than I know, but the engine swap is not uncommon.The car is running well at this point. Power is back where it should be. I am going to replace the plug wires at some point very soon as I still have an occasional hiccup at idle. New plugs with a smaller gap seems to have cleared up the problems. Link to comment Share on other sites More sharing options...
