Domo Posted October 25, 2015 Report Share Posted October 25, 2015 I'm chasing a rich condition based on the reading from my afr gauge and poor fuel consumption afr is 13.1 at idle, I ran a check using vida, no codes at all. I checked the readings on the oxygen sensor it read 0.88v at idle, according to the parameter description reading should be 1.0 anything under 1.0 is rich anything over is lean. My question is do you think my oxygen sensor is failing? Link to comment Share on other sites More sharing options...
gdog Posted October 25, 2015 Report Share Posted October 25, 2015 Actually a narrow-band (NB) O2 sensor's output should fluctuate between 0.1 and 0.9 volts; if you have a rich condition it will spend more time at the 0.9v end. So either your O2 sensor is bad, or something is causing the rich condition (e.g. leak injector maybe). Link to comment Share on other sites More sharing options...
Domo Posted October 26, 2015 Author Report Share Posted October 26, 2015 mine is staying steady at 0.88v at idle Link to comment Share on other sites More sharing options...
hashwilliams Posted November 6, 2015 Report Share Posted November 6, 2015 That's new technology used in volvo, will contact vovlo dealer to fix into my volvo Link to comment Share on other sites More sharing options...
gdog Posted November 7, 2015 Report Share Posted November 7, 2015 By chance does this car come with a wideband (WB) O2 sensor? What's the MY and model? Link to comment Share on other sites More sharing options...
Domo Posted November 27, 2015 Author Report Share Posted November 27, 2015 sorted out the problem the 2000 v70xc does require both oxygen sensors for fuel mixture I noticed that the rear o2 sensor read out was 0.0v because it is disconnected, my tune has it removed. but upon further research I found that the front 02 is a wideband and. just for fun since I have tried everything else trying to correct the problem. I re-connected the rear 02 and presto problem fixed front o2 now reading 1.0v rear o2 reading 0.45v and my wideband gauge confirms this now reading 14.7 at idle. its seems the tune just turned off the ability for the ecm to turn on the check engine light for a rear o2 problem Link to comment Share on other sites More sharing options...
