1999MyC70 Posted November 27, 2015 Report Share Posted November 27, 2015 I am thinking of getting VIDA/DICE and have a couple of questions. First from what I have read it has a bunch of capabilities, can you program a key or fob with it? All the adds I see is that you need Windows 7 Pro only, will it work with later windows? Thanks! Link to comment Share on other sites More sharing options...
wizzard_al Posted November 28, 2015 Report Share Posted November 28, 2015 You have to take the car to the dealer to get keys programmed. They connect to Volvo's server, and that tells the CEM to accept the keys. With the clone DiCE units, you cannot connect to volvo. they throw those units off their system. Supposedly, VIDA works with Win 8, but it takes some work. Look at Swedespeed in the OBD section, there are instructions there. Link to comment Share on other sites More sharing options...
apeacock Posted December 1, 2015 Report Share Posted December 1, 2015 The biggest help I found was to change the ram requirements in the install file down to 2Gb. Even with 4GB in a laptop it wouldn't install. I'm using 2012D and it seems to work just fine. I don't believe you can program keys but it says how many are programmed for the car in case you needed that knowledge. I wish you could do a little more with the p80 cars, both overall and without the use of the software hub at Volvo. A lot of functions are locked without the pay to reprogram function. I used to have it on win 7 64 bit pro, now I have a new windows 10 laptop that I run VMware box and just run the old install virtually with that and the dice unit. Link to comment Share on other sites More sharing options...
