Nathan Nixon Posted January 11, 2016 Report Share Posted January 11, 2016 Only 1 week with MY new car (02 V70 T5) and I have already logged more sunroof repair hours, than driving hours... Upon purchase the sunshade was stuck open. And the sunroof motor would make that awful noise it makes when it does'nt function properly. After removing the glass, i discovered a broken sunshade clip/guide. It caused some scraping of metal on the rail. After removing the sunshade i tried to clean and smooth out the rails best as possible (dremel kit n cloths). Put it back together and could get a smooth slideup and down but window would only retract 1/3 of max possible. Took it a part/cleaned/studied/dreamed...But no matter the adjustment, or key + doorlock "trick" I could apply so far. Its the same result. Only opens 1/3 of the way...So when the rail guides are connected, (as if window would be attached properly) it only achieves 1/3 opening potential. When they are disconnected i can operate the switch to make it "fully" open. Also at NO time, has the sunroof been able to find the "automatic lock" position, so it just slides back down, stopping at 1/3 open. I also cannot get it to stop "whistleing" while driving down the road no matter how close the "window level" is to the "car roof level", IT STILL WHISTLES... Really light, but i hear it! This video shows what I am desribing: 1)What can be done to eliminate the wind noise? 2)Is the real problem the rail that was damaged by the sunshade clip, and needs to be replaced? or is it just not clean enough yet? Any "tricks" for cleaning in that small space? Link to comment Share on other sites More sharing options...
Flukey Posted January 12, 2016 Report Share Posted January 12, 2016 Nightmare.Take 2 asprin and dream up your next fix.I went down that road one time on my kids car.I shut the damn thing tight and disabled it.that fixed it Link to comment Share on other sites More sharing options...
