ovlovturbo Posted March 12, 2016 Report Share Posted March 12, 2016 hello, I have a 2002 s60t5 manual with about 180k on it and have noticed that there is a air pump noise coming from near the bottom of the engine, it can only be heard from either side of the front of the cat tight behind the front wheels, cant really hear it when you open the hood and listen from above. it also does not happen all th time. any ideas or suggestions? Link to comment Share on other sites More sharing options...
Fran9690 Posted March 13, 2016 Report Share Posted March 13, 2016 Doesn't have an air pump on your year. Could be the vacuum pump running for the brake booster that you're hearing, which is normal. Unless it's running all the time, which is not normal. Link to comment Share on other sites More sharing options...
ovlovturbo Posted March 14, 2016 Author Report Share Posted March 14, 2016 ah ok, the times i hair it are when i am outside the car and it is parked. i will double check but i don't think it runs all the time. Link to comment Share on other sites More sharing options...
ovlovturbo Posted March 15, 2016 Author Report Share Posted March 15, 2016 so it is a fluttering sound and it does stop after a while, not always on i guess Link to comment Share on other sites More sharing options...
Fran9690 Posted March 17, 2016 Report Share Posted March 17, 2016 The vacuum pump is more so like a buzzing noise, never really heard a fluttering noise. Like a turbo flutter is what you're hearing? Link to comment Share on other sites More sharing options...
ovlovturbo Posted March 17, 2016 Author Report Share Posted March 17, 2016 not too sure actually, this is at idle when the car is parked, i can't really hear it when i drive the car, maybe it is an exhaust leak although that would be constant and not come and go. Link to comment Share on other sites More sharing options...
