JA VOLVO Posted April 4, 2016 Report Share Posted April 4, 2016 Not sure if this is really an audio issue, but this is the only symptom I have of it. When I turn on my headlights and/or fogs (all are HID, 35watt), the lights on the radio get very dim and then come back. Also, I have a GROM hooked up to the main power line as they instructed and it will reset from, I am guessing, the drop in voltage. I am not too sure what to check. My first guesses are alternator to make sure it is putting out enough normal juice. Other than that, is there anything I should check or is there a way to maintain good voltage to the radio? I know I could add a capacitor, but that seems like a work-around for what is actually going on. I have no other power related issues I am aware of. Link to comment Share on other sites More sharing options...
aharres Posted May 12, 2016 Report Share Posted May 12, 2016 Check if there is a large voltage drop between the battery and the main fuse box. There is a 4-wire cable that tends to corrode or something and will cause a huge voltage drop. For fun, try taking off the cover of the main fuse box and feel how hot the cable gets at the connector. Link to comment Share on other sites More sharing options...
