mattsk8 Posted April 12, 2016 Report Share Posted April 12, 2016 The AWD in my 99 R was gone when I got the car (PO pulled the drive shaft and both rear CV joints). So... I have an opportunity to get a 98 XC parts car for cheap that has a working AWD. Will this bolt into my 99 R? My R has a good bevel gear and rear differential. Link to comment Share on other sites More sharing options...
mattsk8 Posted April 12, 2016 Author Report Share Posted April 12, 2016 Did some research and found out there are 3 different AWD versions... early 98 is all by itself, then late 98 and 99 are the same, and 2000 is all by itself (way to go Volvo ). So I'm getting the VIN from the potential parts car, and I'll figure out if it will work. Link to comment Share on other sites More sharing options...
NEU Posted April 12, 2016 Report Share Posted April 12, 2016 http://v70r.com/forums/topic/33058-98-00-awd-components/ Link to comment Share on other sites More sharing options...
andyb5 Posted April 12, 2016 Report Share Posted April 12, 2016 4 hours ago, NEU said: http://v70r.com/forums/topic/33058-98-00-awd-components/ http://forums.swedespeed.com/showthread.php?163864-98-00-AWD-Component-Parts-Listings More info in the SS version, H was able to go back and edit/update as more information was learned. 8 hours ago, mattsk8 said: The AWD in my 99 R was gone when I got the car (PO pulled the drive shaft and both rear CV joints). So... I have an opportunity to get a 98 XC parts car for cheap that has a working AWD. Will this bolt into my 99 R? My R has a good bevel gear and rear differential. If you use all the 98 components (angle gear, DS, VC) you should be all set. The rear diff and rear axles are the same from year to year. Link to comment Share on other sites More sharing options...
apeacock Posted April 13, 2016 Report Share Posted April 13, 2016 Can't believe they pulled the rear cv joints Link to comment Share on other sites More sharing options...
