div4scpro Posted April 21, 2016 Report Share Posted April 21, 2016 2009 S60 2.5T Sunroof drain issue? On two occasions only the driver’s side has flooded, front and back. I have drained water through both front drain tubes. Can't get to rear drains to drain water but have blown and sucked air through the rear, It seems to come out no problem. Don’t refer to the procedures to any other year or model, please! In a 2009 S60 the front drain tubes for the sunroof are inside the A pillar, that means inaccessible. The stealership won’t even tell me where the soundtrap, the piece at the lower end of the forward drain tubes are located even though the parts department has a part number for it and said they can order it. I have poured water through the sunroof front drain tubes and watched it run it out through seams in the frame about 6in. behind the front wheel well. Does anyone know how to access this soundtrap, endpoint , of the front sunroof drain tubes? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 21, 2016 Report Share Posted April 21, 2016 In the S60 the tubes are made into the A-Pillars, so they are metal. I'm not entirely sure there is even a sound trap on that model. If you can pour water in the front tubes and it drains completely it stands to reason they are clear from any blockage. If you wanted some peace of mind you could try 100psi of shop air, that should clear anything out nicely. There are short sections of rubber tube that can be found at near the sunroof cassette you could check, but you'll need to remove the ohh shit handles and the visors. Link to comment Share on other sites More sharing options...
