Big Will Posted April 27, 2016 Report Share Posted April 27, 2016 I have a good condition heated wide angle mirror with the "bacon" symbol.SOLD Link to comment Share on other sites More sharing options...
MattyXXL Posted April 27, 2016 Report Share Posted April 27, 2016 I dont want to assume LOL this is the drivers side (LHD) correct? If so Ill take it Link to comment Share on other sites More sharing options...
Big Will Posted April 27, 2016 Author Report Share Posted April 27, 2016 Yes indeed it is. Sorry I forgot that detail! I'll send you a PM. Link to comment Share on other sites More sharing options...
Guest Gregory Posted May 4, 2016 Report Share Posted May 4, 2016 Hi Big Will, I've reading your posts for years! Trying to reach you with a question.. For my V70 r 2000 U.S. car, I am going to do the stock euro front parts: spring-3546641/shock-9473850. For the rear: shocks-8626025/ however the euro spring #9200184 is not available…Can I just use the 'regular R' #9173775 rear spring?? I', At least the euro nivo won't pump up the rear as much as the stock nivo.. also I am adding IPD front and rear sway bars. What do you think? Thank you for you help! Gregory Link to comment Share on other sites More sharing options...
Big Will Posted May 5, 2016 Author Report Share Posted May 5, 2016 Hi Gregory. Yes you can definitely use the 9173775 rear spring. Most of the height difference should be in the actual nivomat shock rather than the spring. Also, the front springs that you quoted are not the spring that came with lowered chassis cars. I think that was a mistake on my part. You are better off using 9169021. The front shocks with that part number are indeed the ones listed as coming with lowered chassis Rs but they should be the same as any Sachs front shock. I believe the numbering differences were only to designate car model differences for Volvo. Also, if you want to save a little money, I think Lesjöfors has a good alternative: Front spring: 4095836 Rear spring: 4295841 Link to comment Share on other sites More sharing options...
