Volvo25T Posted May 2, 2016 Report Share Posted May 2, 2016 I have a 2007 volvo s60 2.5T with 63k miles. It has a bumpy/ vibration in the drivdriver's side tire at just about all speeds from 30mph and up. I dont feel it all that much in the steering wheel. I feel it more from the floor board where I rest my foot. At lower speeds it seems like there is a wobble and it.progressively turns into something like hitting bumps over and over again. The tired are 4 months old and the weights are still there. It has stock 17inch tucana rims. With 235 45 17. Any thoughts? Sound like a bent rim? The suspension looks good and only has 63k miles on it and only front left rim/tire. Like wheel homp at all speeds. It vibrates the whole front end pretty much. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 2, 2016 Report Share Posted May 2, 2016 does not sound like a wheel and tire issue, your symptoms indicate you have a bad CV joint. Have you had a look at the axles yet? Link to comment Share on other sites More sharing options...
troyhyde Posted June 10, 2016 Report Share Posted June 10, 2016 Rotate the tires to ensure it isn't an internal steel belt failure (a problem isolated to one tire). Sounds like a balance issue of some variety. Not much rotating except the tires/rotors/wheels, especially if coasting. If on and off "load" driving conditions produce different results, you might have a bad cv joint. Link to comment Share on other sites More sharing options...
co21ss Posted July 18, 2016 Report Share Posted July 18, 2016 I would agree with Ihatespeedbumps that this sounds more like a bad CV joint. Look for any tears on the driver side boots, or grease being slung around under there as a telltale. Link to comment Share on other sites More sharing options...
