ArMiGer Posted May 4, 2016 Report Share Posted May 4, 2016 Can I load stock (Motronic Suite) 446 bin which come from s70 2.0T5 (226hp) on a 608 ECU and plug into S70 2.0T (180hp). The difference between T5 and T is just in the turbos as I know. Engines should be the same. What do you guys think? Link to comment Share on other sites More sharing options...
German850R Posted May 4, 2016 Report Share Posted May 4, 2016 The immo won't let you. Link to comment Share on other sites More sharing options...
ArMiGer Posted May 4, 2016 Author Report Share Posted May 4, 2016 So what would be the better option? 1. Read the original file and change the maps. (original immo on) 2. Transfer the maps to the 608 bin (no immo, right?) Is it possible to safely do one of the above? Any suggestions? Link to comment Share on other sites More sharing options...
German850R Posted May 4, 2016 Report Share Posted May 4, 2016 Use the 608 bin without immo as this will also enable you to datalog etc. Link to comment Share on other sites More sharing options...
aziz Posted May 4, 2016 Report Share Posted May 4, 2016 3 hours ago, ArMiGer said: The difference between T5 and T is just in the turbos as I know. Engines should be the same. What do you guys think? the difference is HPT vs LPT... so much more than just the turbo... investigate a little about different engines/specs - then start to think about selftuning the maps differ quite alot.. greetz Link to comment Share on other sites More sharing options...
ArMiGer Posted May 4, 2016 Author Report Share Posted May 4, 2016 10 hours ago, German850R said: Use the 608 bin without immo as this will also enable you to datalog etc. My concern is that 608 comes from 2.3L car. Would it be enough to just change the maps that come from 2.0T5? 10 hours ago, aziz said: the difference is HPT vs LPT... so much more than just the turbo... investigate a little about different engines/specs - then start to think about selftuning the maps differ quite alot.. greetz Actually I did some research and it's appear that engines from 2.0T5 and 2.0T are with the same internals and compression ratio. I would take the risk to put some more boost on the turbo, as the stock T5 HPT is around 9.5-10psi, and the LPT 2.0T is around 6-8psi. Link to comment Share on other sites More sharing options...
lookforjoe Posted May 6, 2016 Report Share Posted May 6, 2016 You haven't explained why you want to do this. Timing maps are not the same either. Have you investigated using TunerPro? It's pretty easy to switch tables around in that once you have your ECU flashed with a non immobilizer bin & use the appropriate XDF & ADX files Link to comment Share on other sites More sharing options...
