Seaway Posted May 14, 2016 Report Share Posted May 14, 2016 98 V70 T5 Manual -198kLocation: Alexandria, VA This is a solidly built car with some tasteful mods and a ton of maintenance performed on it. It runs well, is very dependable, sounds amazing and surprises people on Highway on ramps. RN swapped motor, conservative tune and tasteful visual mods make it a very fun car. Highlights:2000 V70R engineARD Green tune with SAS delete and rear O2 delete (extra stock ecu included) R interior R door panels R cluster2000 R steering wheel R badged rear hatchR Bumper with Subaru WRX lipH&R lowering springs3rd Row seatingJewel Headlights Meteors with Continental Dws tires Roof rails and cross bars 850R Clutch with 15kBlue injectors Timing belt @175kAngle Flange 16T (extra low mile 16T included) Japanifold Snabb intakeCJ Yother downpipe IPD cat back exhaust 25mm IPD rear sway bar Mishimoto silicone hosesIPD strut braceMSD ignition All new brake calipers pads and rotors within the last year/10kAkebono brake padsSony Bluetooth head unit (stock included) Polk Audio speakers8" powered subwoofer mounted in the rearStainless door sillsBelow is a list of maintenance I have done since buying the car:MAF Sensor (186k swapped in used with 2,000 miles on it)O2 Sensors - OEM Bosch - (186k) 1/18/2015Torque Mount (IPD Poly) 1/26/2015Transmission Mount (Hutchinson OEM) @ 186kSilicone vacuum lines from TCVSnabb intake pipe (w/new PTC valve)Used AC blower motorHeater core (Alvo - improved design) (189K)Mishimoto Intercooler Hoses (188k)Rear Brake calipers, new Bosch Rotors, Akebono pads, new E-brake pads (189K)Left Front Brake Caliper @ 189KMidwest ABS Rebuilt ABS Sensor @ 188kRebuilt Turbo (CHRA) @ 188kJewel headlights and corner markers (New @ 188k)Interior LED lights (188k)ARD Green Tune (17psi)Oil changed (189k) (Rotella T6 5w-40)Cargo coverBattery @ 187k - NAPAAir Filter @ 188kR Gauge ClusterNew Passenger CV Axle (NAPA - $50) @ 191KIPD Strut BraceFront Brake Pads (Akebono) @ 191KBoost Gauge @ 191K (Glow Shift)New thermostat (Calstat 87) @192kNew ECT sensor @ 192kNew Spark Plugs @ 192k (NGK BKR7E gapped @ .025)New Bosch ignition rotor @ 192kReplaced wiper relay with “99” VW relay - intermittent now able to be set - 193kInstalled CJ Yother Down pipe and cat @193k (9/23/15)New cabin air filter @ 193k (10/7/2015)New front rotors @ 193k (Meyle Platinum)New Upper Engine Torque Mount @ firewall @ 193k (Hutchinson - OEM)New Front Engine Mount @ 193k (Rein Brand)IPD rear sway bar installed @ 193k (track spec 25mm)Meyle HD control arms installed @ 193kBosch fuel filter installed @ 193kNew Meyle tie rod ends @193.5kNew transverse arm bolts @193.5kFour wheel alignment @193.5k (10/16/15)Wheels balanced 10/17/2015Oil change 193.5k (Rotella T6 5w-40)New NGK plug wires @ 193.5New Bosch Distributor Cap @ 193.5New MSD Ignition Coil @ 193.5New Rear Shocks (Monroe 5975 OE Spectrum with Monroe 904904 shock mounts) @ 193.7kInstalled Mishimoto silicone lower radiator hose @ 193.8kInstalled Blue Injectors (used) @194.2k - *city mileage up 3mpgNew Wahler 90* Thermostat 12/8/2015New Right Front Brake Caliper 12/13/2015 @ 194.8kInstalled IPD cat back exhaust 12/19/15 @ 195kReplaced reverse light switch 12/19/15 @ 195kReplaced both front fenders at 195.5kInstalled lip on bumper @ 195.5kInstalled stock color MeteorsInstalled new steering coupling @195.7k. *Oil change @ 197,750 - 4/15/16 - *Rotella T6 5w-40This car is basically a V70R without the AWD and associated problems. The T5 Manual was a low production model in the US and there aren't too many around. The car is fast, fun and sounds great. Handles very well and is a blast to drive. Everything works! AC blows cold, heated seats work almost too well, sunroof works great. With great power comes great responsibility and it is time to pass the torch. I have spent a ton of time and money building this car but priorities have changed and it's time to move on. This was my daily driver until about a week ago when I picked up a new Volvo. I hate to let it go, but I just don't have the time anymore. Trying to sell a car on here is impossible because I can't post pics. I will set up an album and provide a link. PM me for any additional information. Car is listed on swedespeed with pics. https://goo.gl/photos/syHyNaShzh2zZKDj7 Link to comment Share on other sites More sharing options...
Wesdunns70t5m Posted May 14, 2016 Report Share Posted May 14, 2016 D: what???? If I had the money id buy it from you right now. I can vouch for how clean this car is and how well it was running less than a year ago! Link to comment Share on other sites More sharing options...
Seaway Posted May 14, 2016 Author Report Share Posted May 14, 2016 Thanks, Wes. It's just time to let it go. I bought a 2008 C30 and I have a little pickup truck that will always need work, so I have stuff to play with. Just trying to lighten the load a bit. It's a great car and after I read all the work I have done it makes me question why I would sell it, but I just don't have time. I took a new job with a long commute, my son is getting older, it's boating season, the list goes on. If anyone has any questions, let me know. Link to comment Share on other sites More sharing options...
Seaway Posted May 17, 2016 Author Report Share Posted May 17, 2016 Sale pending. Deposit received. Link to comment Share on other sites More sharing options...
tuner4life Posted May 17, 2016 Report Share Posted May 17, 2016 Dang, this is awesome!! I wish it was for sale 6 months ago, I would have already bought it lol! Link to comment Share on other sites More sharing options...
Seaway Posted May 17, 2016 Author Report Share Posted May 17, 2016 Thanks. Hopefully the guy buying it will keep it up. It's a fun car. Kinda hurts to know it will be gone, actually. Link to comment Share on other sites More sharing options...
Seaway Posted May 28, 2016 Author Report Share Posted May 28, 2016 Bump. Car is back on the market. Buyer backed out. $4500. Email is best: misterstrachan@gmail.com Link to comment Share on other sites More sharing options...
Seaway Posted May 29, 2016 Author Report Share Posted May 29, 2016 Sale pending. Deposit received. Again. Link to comment Share on other sites More sharing options...
