mattsk8 Posted May 27, 2016 Report Share Posted May 27, 2016 I know there are a million topics on this, and I have definitely read them. I also have Lucas giving me phenomenal advice. What I've found so far... is that the R manifold flows (up to) 30% better than my stock 1999 R manifold, and it moves the hot side of the manifold further from the valve seals, so the valve seals should last longer. Where I'm getting mixed info is on just exactly what year Volvos I should get this manifold from. Most of what I've seen says "2004 to 2007 R", but I've also seen that any of the 2007+ Volvo turbo engines all have that better designed, better flowing manifold as well. If that's true, will a manifold from a 2008 S60 T5 w/ a 2.4L work for me as an upgrade from my R's stock manifold? I've also read that this should bolt up, w/out having to mod my DP. Is that true? Link to comment Share on other sites More sharing options...
NEU Posted May 27, 2016 Report Share Posted May 27, 2016 This information is all over THIS and every other Volvo site. Try ANY '04+ 5 cylinder, it's not just "R" cars, it's just call that, mine came off a '04 xc90. You want one that looks like the top one, the bottom is the 850, you have the Japanifold, which is similar to the 850 but better flowing than the 850 and isn't prone to crack like the 850. Link to comment Share on other sites More sharing options...
gmsgltr Posted May 27, 2016 Report Share Posted May 27, 2016 For others that pop into this thread, page 8 of this thread has amazing info on the advantages of the "R Manifold": Link to comment Share on other sites More sharing options...
mattsk8 Posted May 27, 2016 Author Report Share Posted May 27, 2016 26 minutes ago, NEU said: This information is all over THIS and every other Volvo site. Try ANY '04+ 5 cylinder, it's not just "R" cars, it's just call that, mine came off a '04 xc90. You want one that looks like the top one, the bottom is the 850, you have the Japanifold, which is similar to the 850 but better flowing than the 850 and isn't prone to crack like the 850. I agree that there is info all over, I found threads everywhere and read them. But... there was a lot of mixed info on what is, and what is not a "R manifold". Just wanted to clarify that the 2008 S60 T5 had the manifold I was looking for, because I found one for $90. Also... thank you for clarifying. I will move forward with purchasing this manifold. Link to comment Share on other sites More sharing options...
TryingBe Posted May 27, 2016 Report Share Posted May 27, 2016 http://www.ebay.com/itm/03-04-05-06-07-VOLVO-XC90-EXHAUST-MANIFOLD-5-CYL-32041-/252367799950?fits=Make%3AVolvo&hash=item3ac24b068e:g:JvMAAOSwr41XHoD8&vxp=mtr simple and easy. Link to comment Share on other sites More sharing options...
NEU Posted May 27, 2016 Report Share Posted May 27, 2016 It's as easy as one, two, three... One you want (R), one you have (Japan), and one you don't want (850)... Link to comment Share on other sites More sharing options...
andyb5 Posted May 27, 2016 Report Share Posted May 27, 2016 Neu, my 99 R had an 850 style manifold. Even more reason to upgrade! Link to comment Share on other sites More sharing options...
mattsk8 Posted May 28, 2016 Author Report Share Posted May 28, 2016 14 hours ago, andyb5 said: Neu, my 99 R had an 850 style manifold. Even more reason to upgrade! I'm pretty sure mine does too. Link to comment Share on other sites More sharing options...
Johann Posted May 28, 2016 Report Share Posted May 28, 2016 2.4 T5 also uses that "5 down" manifold. Also B5254T's, LPT, starting 2002. Link to comment Share on other sites More sharing options...
