jeffrey.humble Posted June 11, 2016 Report Share Posted June 11, 2016 2006 S40 2.4 non turbo I tried searching but could not find anything. Charging system lights came on. Alternator belt was missing. Replaced that (after having to replace the tensioner). Now the car will not fire. Tested the alternator, it was fine, tested the starter and it was fine, as is the battery. It sounds like it is either not getting spark or fuel is not getting there. I am thinking it could be either the fuel pump or the distributor not getting fire to the plugs. I guess worst case could be the computer. I have tried to find how to test the above with no luck. Any advice would be greatly appreciated. Thank you Link to comment Share on other sites More sharing options...
Fran9690 Posted June 11, 2016 Report Share Posted June 11, 2016 Any codes? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted June 12, 2016 Report Share Posted June 12, 2016 So the engine is cranking but not starting correct? I second the request for codes stored. Link to comment Share on other sites More sharing options...
