Battleship Posted June 17, 2016 Report Share Posted June 17, 2016 I'm used to having a short tight brake pedal. This car seems to have a long sloppy one that doeant really start to grab till its half way to the floor. It does a little but seems squishy. Is there a way to adjust it or maybe somethings wrong? Could stepping on the brake when the car was off do anything to break the brakes? Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted June 18, 2016 Report Share Posted June 18, 2016 Bleed them Link to comment Share on other sites More sharing options...
ErikS Posted June 18, 2016 Report Share Posted June 18, 2016 Yes, change the fluid and switch to stainless steel brake lines. Link to comment Share on other sites More sharing options...
MrWinkey Posted June 27, 2016 Report Share Posted June 27, 2016 Might want to check the rotor thickness as well ...undersized rotors will certainly cause fade. Link to comment Share on other sites More sharing options...
troyhyde Posted July 2, 2016 Report Share Posted July 2, 2016 Make sure you have full engine vacuum to the booster (hoses / check valve / vacuum ejector - depending on year, grommet to booster). I've observed some poor longevity in the booster vacuum components, the hoses frequently spin around on the connectors/check valve, etc.... Poor vacuum will result in poor brake performance. Also, a leaky booster will deaden the brakes. Ditto bad master cylinder. As others are commenting, bleed brakes with fresh and quality fluid. Re-bed the brakes when you are sure you have all pieces of the puzzle in a good state of health. Link to comment Share on other sites More sharing options...
