TryingBe Posted June 25, 2016 Report Share Posted June 25, 2016 Since I am doing a dual mass flywheel (DMF) to single mass flywheel (SMF) conversion, I thought I'd share what I found about the weights of the clutch parts. Weights are going to be a little off due to wear and machining. 98 DMF setup (well used, disc worn to the rivets) 95 SMF setup (used/machined flywheel, new clutch/plate) Spec SMF clutch setup (lightly used) R SMF clutch and DMF clutch disc have the same diameter, but the DMF have more friction material Link to comment Share on other sites More sharing options...
