Dru323 Posted August 27, 2016 Report Share Posted August 27, 2016 So i recently purchased said vehichle, the AC worked fine and the slider allowed me to either choose auto or whichever fan speed I desired. As of the other day though, when I start the car the AC "off" button and the air "thru cabin" start to blink and now when I slide the fan selector to either on or auto, the fan will come on for a second and then stop and the lights on those same buttons will start blinking. Ive been told that the number of blinks will tell me what issue the system is having, can anyone tell me what the amount of blinks mean? If this is an issue that is common that I should search for on the forums, please direct me to where, as in browsing from my iPhone and the search function leaves something to be desired. Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 28, 2016 Report Share Posted August 28, 2016 The 20 seconds of blinkies just tells you that the ECC is unhappy. The module has to be interrogated by the right kind of scanning tool to tell you what's specifically wrong. Link to comment Share on other sites More sharing options...
540i6speed Posted August 28, 2016 Report Share Posted August 28, 2016 Usually means the fan is drawing too much current and system shuts it down, could be the fan itself or the blower resistor . Before buying new parts you can take out the resistor to check for corrosion on the resistor board that could be shorting it out and clean it up, also can try to clean and lube the blower motor. Link to comment Share on other sites More sharing options...
Dru323 Posted August 29, 2016 Author Report Share Posted August 29, 2016 Thank you for the fast replies guys! I will start investigating that stuff ASAP. Link to comment Share on other sites More sharing options...
Dru323 Posted September 5, 2016 Author Report Share Posted September 5, 2016 Ok so I have the blower motor out as well as the blower fan resistor and it's opened so the board is exposed. I don't see any corrosion on the board or anything. The blower itself is like in a pressed case so I can only get open access to one bearing. Sup with that? Link to comment Share on other sites More sharing options...
Dru323 Posted September 5, 2016 Author Report Share Posted September 5, 2016 Turned out the blower itself had an internal issue. I hooked it up to 12v and it ran for a second and then shut off by itself. Got another one from Don here in Portland and it fired right up! Link to comment Share on other sites More sharing options...
