br-549 Posted October 14, 2016 Report Share Posted October 14, 2016 Hello, I have a line on a V70 XC in clean shape that needs a tranny. I have read all over the place about the issues with that vintage. I also have a line on a 2004 FWD from an S60. Can I use a FWD trans by bolting on the AWD parts and make it an AWD trans? Can I convert a 2001 XC to FWD if I install the 2004 FWD trans? Is the 2004 trans compatible with the 2001? I have the computer for the 2004. What else will I need? I thought I had seen pictures a while back but cannot find the threads. I do not want to take on the project unless there is some hope it can work. Thanks, B- '03 S60, 175K miles Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 14, 2016 Report Share Posted October 14, 2016 FWD is only FWD Link to comment Share on other sites More sharing options...
br-549 Posted October 14, 2016 Author Report Share Posted October 14, 2016 Can you make an AWD FWD? In other words - remove the XC AWD transmission and drive shafts and install the FWD gear from an S60? I just thought it would be a cheap way to get a wagon out of the process. Thanks for your patience for a newby. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 14, 2016 Report Share Posted October 14, 2016 Yes. More to it than that though, different mounts and brackets gotta find one that works for your setup Link to comment Share on other sites More sharing options...
yangotang Posted October 14, 2016 Report Share Posted October 14, 2016 Yes, it's possible. You need: FWD trans, the rear engine mount from a FWD car, the rear engine mount (hydraulic), steering rack from a FWD car, and you'll need to modify the downpipe length. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted October 15, 2016 Report Share Posted October 15, 2016 It should be noted that an 03+ trans will not swap into an 01-02 without some wiring changes and different TCM logic. It's not as easy as swapping brackets and mounts. Link to comment Share on other sites More sharing options...
br-549 Posted October 16, 2016 Author Report Share Posted October 16, 2016 It looks like I should consider the 2001 V70 XC as FWD. I have the front cross member from a 2004 S60 including the rack, transmission and shafts, TCM/ECM. I will need to look into the mounts as I am just learning about Volvos. I cut the wire harness from them, but could graft it all back together again if needed! What is different about the wiring and what is involved? I will hopefully have the complete exhaust system among other stuff tomorrow. The previous owner of the S60 pulled the engine already so I should have everything from the S60. I figured I could put a Volvo V70 together for less than $1000. No problem if it is only FWD. Link to comment Share on other sites More sharing options...
br-549 Posted October 17, 2016 Author Report Share Posted October 17, 2016 I am going to pass on doing such a project for now. The transmission I had a line on fell through. Link to comment Share on other sites More sharing options...
MyBrickIsSlow Posted October 17, 2016 Report Share Posted October 17, 2016 Have you considered a M56 or M66? Not sure where you are located but I know of a few in central Pa. Prices are all pretty reasonable. Of course you have to get the computer programmed. Link to comment Share on other sites More sharing options...
br-549 Posted October 25, 2016 Author Report Share Posted October 25, 2016 Thanks for the reply - I think that I will definitely consider this as an option for a future project. I have worked on our personally owned Chrysler and Ford products for more than 30 years. It was not until I started working on my wife's S60, infrequently as it has been, that I have appreciated them more. I will stay tuned to this website so I can learn more. I get over to the Cleveland area several times per year, I will keep this in mind. Thanks for the suggestion. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 25, 2016 Report Share Posted October 25, 2016 If the P2 is anything like P80, you can mount the AWD engine mounts to a FWD transmission with no issue. The original AWD steering rack can be used as well. (No rear hydraulic mount) Link to comment Share on other sites More sharing options...
