JA VOLVO Posted November 7, 2016 Report Share Posted November 7, 2016 In searching I found from several sources to stick with the Volvo genuine parts for the PCV service kits instead of the FCP and IPD kits as they used URO parts that the hoses were sub-standard and wore out quickly. These threads were several years old however. Is this still the case or is the IPD kit good to go these days? opinions either way would be helpful as I have to do this now... Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted November 7, 2016 Report Share Posted November 7, 2016 I'm not sure what the IPD kit uses now, but I would only feel comfortable with Genuine Volvo for the rubber products. If I'm not mistaken FCP now offers a Genuine/Victor Reinz kit which should suffice. Link to comment Share on other sites More sharing options...
JA VOLVO Posted November 8, 2016 Author Report Share Posted November 8, 2016 cool, I will take a look. Obviously do not want to have to do it again prematurely! Link to comment Share on other sites More sharing options...
JA VOLVO Posted November 8, 2016 Author Report Share Posted November 8, 2016 This is the only kit that FCP has for my car: FCP PCV Kit It does not include the big vacuum line part. Is it important to replace that due to aged rubber? I have sent am email to IPD asking what the brands of the parts in their kits are. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted November 8, 2016 Report Share Posted November 8, 2016 3 hours ago, JA VOLVO said: This is the only kit that FCP has for my car: FCP PCV Kit It does not include the big vacuum line part. Is it important to replace that due to aged rubber? I have sent am email to IPD asking what the brands of the parts in their kits are. That is the kit I always use. I've only ever replaced that large metal pipe once and that is because someone damaged it. You want to add 947282 x2 for the banjo bolt crush washers as well. Link to comment Share on other sites More sharing options...
JA VOLVO Posted November 8, 2016 Author Report Share Posted November 8, 2016 ok, works for me. I am good with $100+ dollars cheaper. Link to comment Share on other sites More sharing options...
apeacock Posted November 9, 2016 Report Share Posted November 9, 2016 Don't use clamps on the lower connection to the block. The ones that come with the FCP kit will deform the metal clamp making it leak! Give Tasca parts a look next time you have an order to make. Link to comment Share on other sites More sharing options...
JA VOLVO Posted November 9, 2016 Author Report Share Posted November 9, 2016 Would you provide a little more detail on this? What should I use instead of clamps? Already ordered the kit from FCP plus new injector and dipstick seals. Link to comment Share on other sites More sharing options...
apeacock Posted November 9, 2016 Report Share Posted November 9, 2016 5 hours ago, JA VOLVO said: Would you provide a little more detail on this? What should I use instead of clamps? Already ordered the kit from FCP plus new injector and dipstick seals. Don't use any clamps on the bottom pcv box drain hose. The part should sit snug on both the box and the hole in the block. That's enough to hole it in and the ones they include don't form a circle when tight. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted November 9, 2016 Report Share Posted November 9, 2016 Use oetiker clamps. I wouldn't recommend not using clamps at all. Link to comment Share on other sites More sharing options...
JA VOLVO Posted November 9, 2016 Author Report Share Posted November 9, 2016 The kit I ordered comes with all oetiker except for two. I will use those. i will evaluate when i get in there. Thanks for the advice guys, i appreciate it. I have never pulled the intake mani before. Link to comment Share on other sites More sharing options...
apeacock Posted November 10, 2016 Report Share Posted November 10, 2016 5 hours ago, JA VOLVO said: The kit I ordered comes with all oetiker except for two. I will use those. i will evaluate when i get in there. Thanks for the advice guys, i appreciate it. I have never pulled the intake mani before. if it's on the 2000 c70 be ready to remove or lay down the alternator as well. The banjo bolt for the coolant / pcv line thing is nearly touching the alternator and needs proper access to refit. 6 hours ago, Tightmopedman9 said: Use oetiker clamps. I wouldn't recommend not using clamps at all. Would certainly give a more circular clamping force on the pieces but it already has a metal cylinder around it and really can't be clamped any more. I've been running no clamp for a while with success. My indy doesn't use them now either. I believe the part was updated at some point. Link to comment Share on other sites More sharing options...
JA VOLVO Posted November 10, 2016 Author Report Share Posted November 10, 2016 Thanks for the tips! I will keep it in mind when I am reattaching everything. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted November 10, 2016 Report Share Posted November 10, 2016 I will agree it is a pain, but some side crimp Oetiker clamps make it easier. I've had leaks from there before, but granted that was with the old style. Link to comment Share on other sites More sharing options...
hootie6828 Posted November 10, 2016 Report Share Posted November 10, 2016 The new style doesn't leak, and does not require clamps. It is a completely different design than the original, and clamps wouldn't do anything at all. Link to comment Share on other sites More sharing options...
