Bpc576 Posted November 27, 2016 Report Share Posted November 27, 2016 hey guys. so on an open straight road i can floor the car while around 10mph. by 50mph im only at 4000 rpm and like 4.5 psi of boost according to my OBD2 scanguage. why is it boosting so low? does the actuator need to be tightened a turn? NO CHECK ENGINE LIGHTS ON by the way. what could be the problem? CAR IS 2000 s40 1.9 Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted November 27, 2016 Report Share Posted November 27, 2016 You have a boost leak, or your wastegate needs to be replaced tightening the actuator isn't gonna do anything, all that does is set the max mechanical boost without a controller, also get a real boost gauge, that obdII scanguage is crap. Link to comment Share on other sites More sharing options...
Bpc576 Posted November 28, 2016 Author Report Share Posted November 28, 2016 i have a boost gauge. just havent had time to install it. im half way done welding a nice bracket for it. I think the wastage is toast. its all rusty and old. i found wastgates online but im not which psi matches up with stock? they offer like a 3,5,9,11,12 psi actuators. and i believe the stock 2000 s40 is a 7.5psi car? but from what i have seen the wastage should be rated at a lower psi then the actual boost allowing it to open gradually? 10 hours ago, Ol' Dirty Noodle said: You have a boost leak, or your wastegate needs to be replaced tightening the actuator isn't gonna do anything, all that does is set the max mechanical boost without a controller, also get a real boost gauge, that obdII scanguage is crap. i have a boost gauge. just havent had time to install it. im half way done welding a nice bracket for it. I think the wastage is toast. its all rusty and old. i found wastgates online but im not which psi matches up with stock? they offer like a 3,5,9,11,12 psi actuators. and i believe the stock 2000 s40 is a 7.5psi car? but from what i have seen the wastage should be rated at a lower psi then the actual boost allowing it to open gradually? Link to comment Share on other sites More sharing options...
