Dougefresh Posted December 18, 2016 Report Share Posted December 18, 2016 Ok.. so I kept the motor/trans and harness all intact for the swap... moved the ecu's over, moved over the ignition, cluster etc... and the car isn't starting. Nothing is unplugged that I can tell.. it's got fuel at the rail and I'll pull a plug tomorrow to verify injectors are pulsing... I pulled a coil pack and ground a plug and it had spark... but the car isn't starting. did I miss something? Is there more that needed swapped over? Anyone got any ideas? I'm fresh out.. I unplugged the MAF, same thing... double checked I have air flow through the intercooler. I'm puzzled at this point. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted December 18, 2016 Report Share Posted December 18, 2016 Gotta start at least three more threads about this in the remaining sub forums before anyone helps 😒 Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 18, 2016 Report Share Posted December 18, 2016 Are you using the keys from the donor unit? Link to comment Share on other sites More sharing options...
Dougefresh Posted December 18, 2016 Author Report Share Posted December 18, 2016 1 hour ago, Ol' Dirty Noodle said: Gotta start at least three more threads about this in the remaining sub forums before anyone helps 😒 Well I'm new to the forum and just trying to post it where the appropriate people see it. 44 minutes ago, Ihatespeedbumps said: Are you using the keys from the donor unit? Yes.. using donor ecu, ecm, cem, ignition, keys etc. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 19, 2016 Report Share Posted December 19, 2016 I'm assuming both cars were left autos? Are you getting any codes stored? Link to comment Share on other sites More sharing options...
Dougefresh Posted December 20, 2016 Author Report Share Posted December 20, 2016 Got it running... so everything I'd swapped over was from the R.. ecu, ecm, motor/trans, ignition... i swapped back to the original ( to shell ) ecu, ecm and ignition and she started... but was throwing a code.. the ecm belongs to a 4 spd transmission.. so I swapped out the ecm' sand she runs with no check lights... so.. I guess that answers that. Somewhere in the car something is stopping me from running the r ecu.. so just gonna have to pony up and get this ecu flashed or tuned and be down the road. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 20, 2016 Report Share Posted December 20, 2016 Glad you got it figured out! Link to comment Share on other sites More sharing options...
savannahvolvoguy Posted January 6, 2017 Report Share Posted January 6, 2017 I'm guessing the new ECU didn't like being attached to the REM UEM or CEM without being linked up appropriately? Possibly a security measure? Link to comment Share on other sites More sharing options...
venderbroeck Posted January 22, 2017 Report Share Posted January 22, 2017 I believe the CEM is part of the immo system. You can pull the bins off of each ecu and check if they have the same architecture. If they do, then you can probably get away with just flashing the correct immo file to the R ecu. Link to comment Share on other sites More sharing options...
