Yellow95 Posted January 6, 2017 Report Share Posted January 6, 2017 1998 S70. 901 stereo with underseat amp. I have the aux in through the 6cd changer slot. Cant think of the name but the yellow box that everyone uses. Recently wile using the MP3 player if I hit a bump 3 channels cut out and I only get sound through the driver door speaker. If I turn off the stereo and turn it back on the sound returns to all speakers until I hit a bump again. The catch is that this doesn't happen when I use the radio. If it didn't turn back on when I shut the radio down and turned it back on I would suspect the aux unit but as it is now I have no clue. Suggestions? Link to comment Share on other sites More sharing options...
BEJinFBK Posted January 6, 2017 Report Share Posted January 6, 2017 It's a long shot, but unplug the 6 pin DIN AMP connector at the back of the 901 and plug it back in. You may have dirty contacts and reseating the plug might help. Link to comment Share on other sites More sharing options...
Yellow95 Posted January 6, 2017 Author Report Share Posted January 6, 2017 1 hour ago, BEJinFBK said: It's a long shot, but unplug the 6 pin DIN AMP connector at the back of the 901 and plug it back in. You may have dirty contacts and reseating the plug might help. I will try that. Thank you sir. Link to comment Share on other sites More sharing options...
Oreo931 Posted January 6, 2017 Report Share Posted January 6, 2017 6 hours ago, Yellow95 said: 1998 S70. 901 stereo with underseat amp. I have the aux in through the 6cd changer slot. Cant think of the name but the yellow box that everyone uses. Recently wile using the MP3 player if I hit a bump 3 channels cut out and I only get sound through the driver door speaker. If I turn off the stereo and turn it back on the sound returns to all speakers until I hit a bump again. The catch is that this doesn't happen when I use the radio. If it didn't turn back on when I shut the radio down and turned it back on I would suspect the aux unit but as it is now I have no clue. Suggestions? For what it's worth, I had the same aux unit in my car and it went bad eventually. I think something shorted internally. I replaced it with a Grom unit and haven't had a problem since. Link to comment Share on other sites More sharing options...
gmsgltr Posted January 9, 2017 Report Share Posted January 9, 2017 same adam^ Link to comment Share on other sites More sharing options...
