apeacock Posted January 10, 2017 Report Share Posted January 10, 2017 Getting consistent gear oil leakage from my 2000 XC. Going to re do the two outer axles seals. The output shaft was already done. I only see / smell gear oil so I presume there is no leaking transmission fluid. 1.Do I need any more then #2 & #3 listed in this diagram? I have 2 of each. #2 is 9143885 #3 is 30735126 2. Should I pull apart the two halves and reseal that as well? If so, what with? Doing the turbo drain seals while I'm in there as well. Thanks. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 10, 2017 Report Share Posted January 10, 2017 You sure it's not leaking from the front sea/o-ring #3 and 4? That's the most common leak and a hell of a lot easier to fix than resealing the whole thing. If it were my car I'd clean it off and try to pinpoint where it's coming from. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted January 10, 2017 Report Share Posted January 10, 2017 IF YOU DO THE DRAIN ANYWAY, CHECH ALSO #3 INER(BETWEEN BG AND TRANNY), I USED ANAEROBIC SEAL LIKE CAM COVER AND WORKS GREAT. Link to comment Share on other sites More sharing options...
apeacock Posted January 11, 2017 Author Report Share Posted January 11, 2017 1 hour ago, Ihatespeedbumps said: You sure it's not leaking from the front sea/o-ring #3 and 4? That's the most common leak and a hell of a lot easier to fix than resealing the whole thing. If it were my car I'd clean it off and try to pinpoint where it's coming from. Minimal coming from that side. Cleaned up a little while ago and its back in force at the transmission side. I was advised to not mess with the #4 big o-ring seal. I've #2 x2 and #3 x2. 1 hour ago, TIZIO AKA 1 HND MEC said: IF YOU DO THE DRAIN ANYWAY, CHECH ALSO #3 INER(BETWEEN BG AND TRANNY), I USED ANAEROBIC SEAL LIKE CAM COVER AND WORKS GREAT. Planning on it. I've got 2 of each of #2 and #3. The pink anaerobic you mean? Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted January 11, 2017 Report Share Posted January 11, 2017 7 minutes ago, apeacock said: Minimal coming from that side. Cleaned up a little while ago and its back in force at the transmission side. I was advised to not mess with the #4 big o-ring seal. I've #2 x2 and #3 x2. Planning on it. I've got 2 of each of #2 and #3. The pink anaerobic you mean? YES,PINK ANAEROBIC IS HE ONE YOU WANT. Link to comment Share on other sites More sharing options...
apeacock Posted January 11, 2017 Author Report Share Posted January 11, 2017 Just now, TIZIO AKA 1 HND MEC said: YES,PINK ANAEROBIC IS HE ONE YOU WANT. Maybe ill go half and half to match the info i've gotten. How long do you think it takes to cure? Doing this Friday in a garage with cold temps. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted January 11, 2017 Report Share Posted January 11, 2017 FOR BEST RESULT BRING EVERYTING IN THE HOUSE AND DO IT THERE, IT WILL NOT WORK IF THE HALF'S ARE BELLOW 40F. USE SOME TARPS,RAGS. IS A 10 MIN JOB 4 THE SEAL TO CURE.THAT I WILL DO. Link to comment Share on other sites More sharing options...
apeacock Posted January 15, 2017 Author Report Share Posted January 15, 2017 So the left had seals 2 & 3 live very far down in the sleeve and the angle gear respectively. The transmission side was totally dry and so we decided to leave them be. The big seal on the exposed passenger side was the most likely culprit. Cleaned up Filling it through a long funnel from above the engine. Took about 98% of the 1L bottle. Driven 100+ miles on it with no leaks and no foul burning smell. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted January 23, 2017 Report Share Posted January 23, 2017 what oil are you using in that? Link to comment Share on other sites More sharing options...
Midnight Caller Posted January 26, 2017 Report Share Posted January 26, 2017 He should be using P/N 31259380, OEM VOLVO for bevel gear. Link to comment Share on other sites More sharing options...
