ConorV70R Posted January 10, 2017 Report Share Posted January 10, 2017 So i've been getting some really long starts lately. The car will crank just fine and sputter then catch a rough idle for a bit and sometimes hold it until it smooths out. Other times it just doesn't catch at all. Once up and going it drives absolutely fine and it also starts right up after sitting over night. Brand new MAF, Spark plugs, fuel relay, and only 10k on the ignition coils. Also new fuel filter at the same time as the coils. I'm assuming it's something fuel related but can't figure out what. Any help is appreciated thanks Link to comment Share on other sites More sharing options...
Honeyman Posted January 10, 2017 Report Share Posted January 10, 2017 Check this out... https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&cad=rja&uact=8&ved=0ahUKEwiOx5K18LfRAhXKxVQKHc38A8kQFgh3MAY&url=http%3A%2F%2Fv70r.com%2Fforums%2Ftopic%2F32025-external-fuel-line-check-valve-hard-starts%2F&usg=AFQjCNH0syJDSGQyWA9_j_-Gkp6d86mpFw Link to comment Share on other sites More sharing options...
ConorV70R Posted January 10, 2017 Author Report Share Posted January 10, 2017 so what is the actual fix beside the check valve. I actually live right by sherman and he was telling me how much of a headache he went through with that. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 10, 2017 Report Share Posted January 10, 2017 It's very likely the pressure bleeding off into the pump. Have you hooked up a fuel pressure gauge at the rail and checked residual pressure with the key off after 20 minutes? Link to comment Share on other sites More sharing options...
hootie6828 Posted January 10, 2017 Report Share Posted January 10, 2017 If this really is your problem, the correct fix is to replace the fuel pump which will replace the check valve as well. Link to comment Share on other sites More sharing options...
FrankenMoose Posted January 11, 2017 Report Share Posted January 11, 2017 17 minutes ago, hootie6828 said: If this really is your problem, the correct fix is to replace the fuel pump which will replace the check valve as well. I can second this. My 2000 VR was doing the same thing just after I bought it. I had the OE pump replaced under warranty and it cleared up instantly. Link to comment Share on other sites More sharing options...
ConorV70R Posted January 11, 2017 Author Report Share Posted January 11, 2017 fuel pressure is just fine. did throw a code for my coolant sensor being faulty and got the bouncey temp gauge on the dash. replacing that and the t stat this weekend. would that have anything to do with this? FYI the car has started just fine for the last two days.... I sometimes feel like a crazy person with this car and it's moods Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 11, 2017 Report Share Posted January 11, 2017 A faulty ECT can certainly cause hard starts on this model. Link to comment Share on other sites More sharing options...
ConorV70R Posted January 11, 2017 Author Report Share Posted January 11, 2017 ok hopefully this fixes it and thankfully it's a fairly easy fix. i'll report back after the weekend when i can get it in. Link to comment Share on other sites More sharing options...
ConorV70R Posted January 16, 2017 Author Report Share Posted January 16, 2017 ECT must of been the last piece of the puzzle. Switched it out with a new thermostat as well and any and all issue have so far been figured out. Cars running absolutely amazing the last three days. Thanks for the advice and heads up on stuff. Link to comment Share on other sites More sharing options...
