JohnHe Posted January 11, 2017 Report Share Posted January 11, 2017 I just swapped the engine and transmission in my 2000 Volvo s70. when I started it up the car immediately revs to 3000 rpms, when I put it in gear the Rpms lower to 1200 but it jumps up and down. the is throwing random misfire codes and faulty communication with throttle body. I switched the coils and the same cylinders are misfiring. I switched the throttle body and idle air control valve and no change. Anyone have a clue of what could be causing this Link to comment Share on other sites More sharing options...
hootie6828 Posted January 11, 2017 Report Share Posted January 11, 2017 If you have a 2000 you shouldn't have an idle air control valve. What year car did the new motor come from? Link to comment Share on other sites More sharing options...
TryingBe Posted January 11, 2017 Report Share Posted January 11, 2017 You probably have a vacuum leak. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 11, 2017 Report Share Posted January 11, 2017 1 hour ago, TryingBe said: You probably have a vacuum leak. This, sounds like a large vacuum leak. Link to comment Share on other sites More sharing options...
