TryingBe Posted June 2, 2017 Report Share Posted June 2, 2017 I have a bunch of whiteblock T5 performance parts. Most parts are for 850 turbo and early C70/S70/V70 turbo. Block and transmission are not in picture. Parts are located in Mesa, AZ 85204. NOT looking to ship the short block.Rebuild 01 block with RSI rods, stock pistons, new rings, polished crank, new bearings, honed block $1000http://www.thelostartof.net/tryingbe/forsale/t5block/ 98 M56H using internal slave cylinder. $400 Picture on request. Japanese manifold $80 Rebuilt custom turbo with Volvo flange by AZ turbo. The compressor wheel is a T04B 60-1, AGP anti-surge compressor housing, single ball bearing, stage III turbine wheel, and a/r .63 turbine housing. BIG power can be made with this. $650 ATP Ultimate waste gate, ceramic coated. $150 URO throtle body hose $5 Headlight cover $10 for both Upper Poly mount $10 Black glove box cover $10 Cabin air filter conversion kit for early 850. $5 Tan glove box cover $10 Arm rest. $15 19T actuator. Holds vacuum just fine. $40 98 Volvo Turbo T5 M4.4 ECU. Ready for tune it yourself. SOLD OBX Racing Sport Turbo Back Exhaust 94-04 Volvo 850 C70 S70 V70 T5 W/ Downpipe FLAT FLANGE ONLY. Never used, never mounted. SOLD Used spec stage 3 clutch and pressure plate, comes with new threw-out bearing. I was told it was use a few thousands miles. Plenty of meat left. For single mass flywheel, 850/C70/S70/V70 SOLD ATF oil coolers, 3/8 hose in and out. SOLD Link to comment Share on other sites More sharing options...
tuner4life Posted June 2, 2017 Report Share Posted June 2, 2017 How are the cup holders in that armrest? Dibs if they aren't broken. Link to comment Share on other sites More sharing options...
Boomin850 Posted June 2, 2017 Report Share Posted June 2, 2017 Damn man...5hrs later and the exhaust is already sold! If that changes, lemme know. Thanks Mike! Link to comment Share on other sites More sharing options...
