Teal854T Posted July 14, 2017 Report Share Posted July 14, 2017 2006 V50 T5 120k miles. I had P0300 ,0302, 0303, 0620 a day before. I reset the CEL and today I got P0300, 0304, 0305, 2292. It shakes during start up then it goes away. About a month ago I got P0303 and replaced spark plugs and coils. No more CEL until 2 days ago. What's going on? Need help. Thanks Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 14, 2017 Report Share Posted July 14, 2017 You ever replaced the fuel pressure sensor? With the P2292 I'm thinking that may be what's causing the misfire codes. Link to comment Share on other sites More sharing options...
Teal854T Posted July 15, 2017 Author Report Share Posted July 15, 2017 I don't think it's been replaced. I bought it used about 6 months ago. Where is it located at? Thanks Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 17, 2017 Report Share Posted July 17, 2017 It's light gray and on the end of the fuel rail Link to comment Share on other sites More sharing options...
Teal854T Posted July 27, 2017 Author Report Share Posted July 27, 2017 Replaced fuel pressure sensor. Drove about 500+ miles for a few days with no issue. Now P0300, 0302, 0304, 0305. Car shakes a lot during start up. Runs fine after that. No problem while driving, no missing. Fuel or electrical problem? Thanks Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted July 27, 2017 Report Share Posted July 27, 2017 Did you use OEM plugs and coils? Link to comment Share on other sites More sharing options...
thedrill Posted July 28, 2017 Report Share Posted July 28, 2017 Do you have a lot of vacuum suction at the dipstick and oil cap? The oil filter housing is prone to fail with a split diaphragm and that can cause rough starting and misfire codes. Link to comment Share on other sites More sharing options...
Teal854T Posted August 1, 2017 Author Report Share Posted August 1, 2017 Coil and spark plugs from IPD. No vacuum at dipstick. Car shakes during cold start but not every cold start. It happens a few times a week. After reset the CEL car runs good for a few days and shakes come back again and CEL. I had bad coil on my other car. Bad coil gave me same obd code after reset. My Volvo give random p0301 to p0305. I'm going to replace injectors. Thanks Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted August 1, 2017 Report Share Posted August 1, 2017 Doubtful the injectors are going to do anything. I would measure the fuel pressure at the rail with a mechanical gauge, should be around 400kpa at idle. You also need to check residual fuel pressure, should not drop more than 100kpa in about 20 minutes. Link to comment Share on other sites More sharing options...
Teal854T Posted August 1, 2017 Author Report Share Posted August 1, 2017 I used wifi code reader with Torque Pro to get the fuel pressure reading. It showed 48.5psi (334kpa) at idle. Residual pressure 50psi (344kpa). Does this car have fuel filter outside the tank? Thanks Link to comment Share on other sites More sharing options...
thedrill Posted August 1, 2017 Report Share Posted August 1, 2017 The filter is built into the pump. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted August 2, 2017 Report Share Posted August 2, 2017 Your torque pro app isn't going to give you residual pressure with the key off. Link to comment Share on other sites More sharing options...
