JaredR1 Posted October 9, 2017 Author Report Share Posted October 9, 2017 2 hours ago, andyb5 said: Yup. They're the same. To reiterate the above, the RNC exhaust gasket is 1 piece MLS, which makes it a popular replacement on the earlier motors. I'm running one on my 99 R motor. I'd post a picture but it's on photobucket so... Ah good point. I see people doing that upgrade all the time; should have connected those dots. Link to comment Share on other sites More sharing options...
Andzey Posted December 23, 2017 Report Share Posted December 23, 2017 Could someone please share thoughts about 93.2 mm stroke crankshaft. Would it be correct call it RNC crank? It is a very popular mod using this crank for larger stroke setups. This normally involves using RNC rods in order to compensate 3.2 mm piston height difference, right? If the RNC crankshaft embeds in RN block, this would mean that RNC and RN have same piston center-to-center distance, and same rod bearing axial spacing. I'd appreciate if someone could confirm this from real-life experience. Link to comment Share on other sites More sharing options...
