gilber33 Posted January 30, 2018 Report Share Posted January 30, 2018 The blower motor quit in our 06 XC90 suddenly. Will not turn on in manual or auto climate settings. I pulled the codes in VADIS and got a code for blower motor signal too low and as a result the car does not allow it to run. I also got several other codes related to the ECC system. Both screen shots are attached. I think this is a chicken or the egg scenario. I'm wondering if the system detected a failed blower motor and it shuts down the ECC system, would that ultimately trigger the other DTCs? Or is the blower motor DTC part of a larger issue? I haven't checked the signal wires for the blower motor yet. That's tonight. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 30, 2018 Report Share Posted January 30, 2018 You are likely going to need a blower motor/power stage. Read the directions before you start, it's going to be fun... Link to comment Share on other sites More sharing options...
gilber33 Posted January 30, 2018 Author Report Share Posted January 30, 2018 36 minutes ago, Ihatespeedbumps said: You are likely going to need a blower motor/power stage. Read the directions before you start, it's going to be fun... I was going to start with that at least. I found several write ups of doing the blower motor without removing the dash. Just have to sacrifice one of the bolt brackets. Which is better than removing the dash. Link to comment Share on other sites More sharing options...
boxpin Posted January 30, 2018 Report Share Posted January 30, 2018 I have pulled the squeaky blower motor out twice in our XC90, no big deal. With the carpet and pad pulled back there is plenty of room to get to that back screw. I know that does not help you with the issue but at least is a little reassuring about removing the fan. Link to comment Share on other sites More sharing options...
gilber33 Posted January 30, 2018 Author Report Share Posted January 30, 2018 Thanks, that does help. I'm assuming it's the blower motor. Everything I've read sound like it's a common failure. I haven't seen anything where's it's an entire system failure. Link to comment Share on other sites More sharing options...
