Teal854T Posted March 1, 2018 Report Share Posted March 1, 2018 2006 V50 T5 radiator has small leak. I've been searching for instruction for removal and can't find any. Need instruction on how to remove it. Thanks Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 1, 2018 Report Share Posted March 1, 2018 You sure it's the radiator? They are solid aluminum and I've never seen one leak. I'd probably be looking at the lower radiator hose a little closer... Link to comment Share on other sites More sharing options...
Teal854T Posted March 1, 2018 Author Report Share Posted March 1, 2018 It's leaking from bottom (driver's side). If you look at the picture above, the leak is on left side. I can see drops on inter cooler hose. Top hose is dried. Thanks Link to comment Share on other sites More sharing options...
Volvo5.0 Posted March 2, 2018 Report Share Posted March 2, 2018 Anything is possible, but I've also never seen these radiators leak. Done my share of A/C condensers though, so check that while you're in there. Not a bad job, but only after you have done a few of them. First time around will be no fun. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 2, 2018 Report Share Posted March 2, 2018 20 hours ago, Teal854T said: It's leaking from bottom (driver's side). If you look at the picture above, the leak is on left side. I can see drops on inter cooler hose. Top hose is dried. Thanks Drivers side is where the lower hose goes in.... You've got a lot of real world experience trying to help you in this thread... Link to comment Share on other sites More sharing options...
