Teal854T Posted March 4, 2018 Report Share Posted March 4, 2018 When does the cooling fan come on, at what temperature? I hooked up obd2 reader and coolant temp showed from 87 to 104 degree C but the gauge in the car showed a little over half. Fan didn't come on. Fan came on when a/c is on. Is something wrong with the temp sensor? 2006 V50 T5 Thanks Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 5, 2018 Report Share Posted March 5, 2018 The fan is a PWM signal from the ECM and comes on based on a variety of factors (ECT, ambient temp, A/C etc.) I don't recall seeing a specific temp where the fan is set to "on" I think if the fan comes on when you turn on the a/c you are just fine. Link to comment Share on other sites More sharing options...
troyhyde Posted April 10, 2018 Report Share Posted April 10, 2018 Not sure what temp is set for your 2006 car but a lot of my Volvo's (varying years) turn on the fan at 210-215 degrees fahrenheit (from memory). This is with the A/C off. With the A/C on the fan is on. The "middle" of the temp gauge will probably not deviate from 160-220 degrees fahrenheit. There is a giant flat spot to prevent paranoia of heat issues. Link to comment Share on other sites More sharing options...
