Highny Posted April 21, 2018 Report Share Posted April 21, 2018 Hi everyone, I've been a lurker for awhile and manage to find answers to most of my questions with search. However, this one got me stumped. I recently got my hands on a 1998 V70 AWD 5 speed manual. The guy who sold me the car said the torque tube's viscus coupling was worn, lucky for me, the car came with an replacement. After replacing the torque tube I found something strange with the angle gear. It free spins with the car in gear. So I thought the connecting sleeve was worn. After spending a few hours taking the angle gear out, I found out the angle gear is in good shape(lacking a bit of oil). The splines for the transmission side was jagged and the sleeve was completely worn! I doesn't even contact. Does anyone know if I could replace the output shaft from an automatic transmission into my manual transmission? The 5 spd AWD is super rare in Canada, and the US never got this option(from what I've been told). I really want the AWD to work, if not, I mind as well trade it for an actual FWD with more upgrade option(I have Nivomat shocks for rear....). Any help and advice is greatly appropriated. Link to comment Share on other sites More sharing options...
BlackT5 Posted April 25, 2018 Report Share Posted April 25, 2018 The splines are worn on the trans side? Normally they strip out on the angle gear side. To answer your question, you can't swap the output shaft from an auto. The splined shaft is actually part of the differential inside the trans. I don't know if there are any aftermarket diffs available for the M58, but that would be an option. Otherwise I imagine you would need a stock diff from another M58 box. If you do decide to go FWD and want an M56, I have one I could send you if you can't find any locally. I'm in Victoria. Link to comment Share on other sites More sharing options...
Freefall Posted April 26, 2018 Report Share Posted April 26, 2018 And then something to worry about, where did those teeth go? It,s easy to guess me thinks. A lot of angle gears die soon after the sleeve/splines wore out. Link to comment Share on other sites More sharing options...
