Domo Posted May 22, 2018 Report Share Posted May 22, 2018 I've got codes from vida that all five ignition coils are too low, last week my 2000 v70xc blew the fuse on my wife's car for the coils leaving her on the side of the road. I found coil number five had melted, I replaced all 5 coils and thought I had fixed the problem until today when we felt a misfire at 2000rpm, I checked the codes and found all five reporting signal to low has anyone had this issue? Or an I the first. I'll start by checking the wiring and grounds I guess. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 22, 2018 Report Share Posted May 22, 2018 I would start by inspecting the wiring harness on top of the engine. It's not unheard to pinch a wire to one of the coils when putting the plastic covers back on. Link to comment Share on other sites More sharing options...
Domo Posted May 22, 2018 Author Report Share Posted May 22, 2018 I will start there Tonite, what's weird is I haven't touched it in at least a year, I find it strange that searching the web not one person has had this issue I also find it strange that I have a signal too low on all five coils and not just one or two I understand and respect what you are saying about a pinched wire, I hope it is that simple, because after last week seeing it melt a coil I'm feeling a bit nervous Link to comment Share on other sites More sharing options...
Domo Posted May 23, 2018 Author Report Share Posted May 23, 2018 Inspected coil wiring last night everything looked fine Link to comment Share on other sites More sharing options...
gdog Posted May 24, 2018 Report Share Posted May 24, 2018 Did you check supply voltages (I'm assuming it was the supply voltage that was low?) at the coils? Speculating here, but if the coil got drew enough current to melt it and blow the supply fuse, then it possibly overheated the harness as well giving it a higher resistance than before the incident. The extra resistance would give you a voltage drop. Link to comment Share on other sites More sharing options...
Domo Posted May 24, 2018 Author Report Share Posted May 24, 2018 17 hours ago, gdog said: Did you check supply voltages (I'm assuming it was the supply voltage that was low?) at the coils? Speculating here, but if the coil got drew enough current to melt it and blow the supply fuse, then it possibly overheated the harness as well giving it a higher resistance than before the incident. The extra resistance would give you a voltage drop. I have not checked that yet, according to vida it is the signal wire that is causing the problem rather than the supply voltage. If i check it should it be reading 12v? I've inspected the harness back to the main loom on top of the trans and everything looks normal. so far Link to comment Share on other sites More sharing options...
gdog Posted May 24, 2018 Report Share Posted May 24, 2018 Again, my post is all conjecture.. What were the actual codes? Link to comment Share on other sites More sharing options...
Domo Posted May 25, 2018 Author Report Share Posted May 25, 2018 ecm-3300 ignition coil cylinder 1 signal- signal too low ecm-3310 ignition coil cylinder 2 signal-signal too low ecm-3320 ignition coil cylinder 3 signal- signal too low ecm-3330 ignition coil cylinder 4 signal-signal too low ecm-3340 ignition coil cylinder 5 signal-signal too low Link to comment Share on other sites More sharing options...
Domo Posted June 1, 2018 Author Report Share Posted June 1, 2018 Just to help anyone else that has this issue I changed coils, plugs and inspected and re taped all the wiring for the coils so far so good. no codes since last week Link to comment Share on other sites More sharing options...
gdog Posted June 2, 2018 Report Share Posted June 2, 2018 On 5/21/2018 at 6:49 PM, Domo said: I've got codes from vida that all five ignition coils are too low, last week my 2000 v70xc blew the fuse on my wife's car for the coils leaving her on the side of the road. I found coil number five had melted, I replaced all 5 coils and thought I had fixed the problem until today when we felt a misfire at 2000rpm, I checked the codes and found all five reporting signal to low has anyone had this issue? Or an I the first. I'll start by checking the wiring and grounds I guess. 13 hours ago, Domo said: Just to help anyone else that has this issue I changed coils, plugs and inspected and re taped all the wiring for the coils so far so good. no codes since last week You're saying you replaced all 5 coils 2x? Used or new? Link to comment Share on other sites More sharing options...
Domo Posted June 2, 2018 Author Report Share Posted June 2, 2018 All five coils once with new ones and new OEM plugs Link to comment Share on other sites More sharing options...
