gordiesideways Posted May 29, 2018 Report Share Posted May 29, 2018 Short story long then, water pump seized, spat off timing belt, bent 12 valves. Got a replacement engine from a slightly younger s60. Prior to the belt coming off, the only fault present was an intermittent throttle body fault. Anyway, stripped everything off both engines. New timing belt kit and water pump on to new engine, vvt not touched. Every sensor original to the car put on the new engine, even flywheel and clutch. Now I have nigh on impossible to start cold, misfire, 3500 rpm limiter, emission service urgent, cel and the only code is p0336. Have swapped out crank sensor with one from another car that is known good, and done a hard reset. Is my cam timing off? I timed it to the marks when replacing the belt, but I didn't move the vvt hub, however I didn't hear the engine running before I bought it. Only thing left I can think to check. Any more ideas? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 30, 2018 Report Share Posted May 30, 2018 Your timing is off. Lock the cams down and follow this video; Link to comment Share on other sites More sharing options...
gordiesideways Posted May 30, 2018 Author Report Share Posted May 30, 2018 3 hours ago, Ihatespeedbumps said: Your timing is off. Lock the cams down and follow this video; Cheers bud😉 Link to comment Share on other sites More sharing options...
