nik77 Posted June 16, 2018 Report Share Posted June 16, 2018 Hi My S60 T5 pop up with error codes P0193 (fuel pressure to high) and P0036 (O2 sensor related) Is it safe to drive? Im more concern on P0036 related to 02 sensor. Any possibility this 02 sensor causing lean air-fuel mixture? Thanks Link to comment Share on other sites More sharing options...
bmdubya1198 Posted June 16, 2018 Report Share Posted June 16, 2018 I wouldn’t worry about the O2 sensor code. That is about the heater circuit, which may be just a bad O2 sensor. It shouldn’t do any harm. The other code would be my bigger concern. That could be an issue with the fuel pressure sensor. See this thread: http://forums.swedespeed.com/showthread.php?121174-P0193-Fuel-Rail-Pressure-Sensor-Circuit-High-Input#/topics/121174 Link to comment Share on other sites More sharing options...
nik77 Posted June 16, 2018 Author Report Share Posted June 16, 2018 Thanks. Could the P0193 problem damage the engine? If yes, in what way it could damage the engine? Most of time it difficult to start the engine. Sometimes unstable idle happened I use Ultragauge to reset the code. After reset, it's start normally Thanks Link to comment Share on other sites More sharing options...
bmdubya1198 Posted June 17, 2018 Report Share Posted June 17, 2018 Unstable idle sounds like that fuel pressure switch is likely your issue. Especially since you say it runs normally after clearing the codes. It's probably not going to cause any damage, but I would make that a high priority to replace that. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted June 18, 2018 Report Share Posted June 18, 2018 It would be helpful if you told us what year your S60 is and what engine it has :) Link to comment Share on other sites More sharing options...
bmdubya1198 Posted June 18, 2018 Report Share Posted June 18, 2018 2 hours ago, Ihatespeedbumps said: It would be helpful if you told us what year your S60 is and what engine it has :) I kept looking for the year in the OP... that would be helpful info! Link to comment Share on other sites More sharing options...
nik77 Posted June 23, 2018 Author Report Share Posted June 23, 2018 Hi The S60 T5 is year 2007. K24 turbo. Engine B5244T. Front wheel drive. 260bhp. 350nm. Already tuned but never test on dyno. The tuner said from his previous tuned, it should get 310 bhp and 420nm. Full higher flow TME exhaust system 3" to cat. After cat, 2.5". Ebay Fmic, Setrab 19 rows oil cooler and 16 rows Atf cooler. Deatschwerk 255 lph pump. The only restriction are 395cc blue injectors. Need green injectors Great pulling power from 2500rpm. I think need to remap and eliminate torque limiter in 1st and 2nd gear. Always beaten by Golf GTIs at traffic light.lol Link to comment Share on other sites More sharing options...
bmdubya1198 Posted June 23, 2018 Report Share Posted June 23, 2018 Sounds fun! Any luck with the fuel pressure switch? Link to comment Share on other sites More sharing options...
