Geevs Posted July 9, 2018 Report Share Posted July 9, 2018 When I took off my front wheel, I found a piece of round rubber freely resting on the subframe. The part number is 3507606 and searching google returned "Front Mount Buffer". http://www.skandix.de/en/spare-parts/engine/engine-mountings/buffer-engine-mount/1052021/ Mine looks like this except the rubber tab has broken off. What is the purpose of this piece? And how important is it to get this piece replaced with a new one? Thanks! Link to comment Share on other sites More sharing options...
TryingBe Posted July 9, 2018 Report Share Posted July 9, 2018 It stops the engine hitting the subframe. Link to comment Share on other sites More sharing options...
Brad850 Posted July 9, 2018 Report Share Posted July 9, 2018 If your trans casing was resting on or touching the pad it means you should replace your two main hydraulic motor mounts. The pad is more of an indicator of motor mount health, rather than a bump stop. Yes it will stop the trans from hitting the subframe, but under normal conditions your trans casing should never be making contact with it. I would replace it with a new one. Link to comment Share on other sites More sharing options...
Geevs Posted July 9, 2018 Author Report Share Posted July 9, 2018 Thanks guys! On another note, I've started to notice an intermittent clicking/ticking sound after I turn off the engine. The sounds comes every 5 seconds or so, and lasts for a couple of minutes. What could be causing this? Link to comment Share on other sites More sharing options...
bmdubya1198 Posted July 16, 2018 Report Share Posted July 16, 2018 What kind of ticking? Do you mean ticking from the exhaust cooling off? Link to comment Share on other sites More sharing options...
sventastic Posted July 16, 2018 Report Share Posted July 16, 2018 3 hours ago, bmdubya1198 said: What kind of ticking? Do you mean ticking from the exhaust cooling off? That's what it sounded like to me when Geevs showed me his car Link to comment Share on other sites More sharing options...
