Th3Nigh7Stalk3r Posted February 17, 2019 Report Share Posted February 17, 2019 I just bought a 2001 S60. When the engine is hot or at its operating temperature, usually during heavy traffic and such. The trans tends to slip between gears 2 and 3, and then back down between 3 and 2. If I floor it, it high revs around those gears and then shifts. I’m new to a Volvo and am just looking for some information about or help with this situation. Thanks in advance Link to comment Share on other sites More sharing options...
Chris81964 Posted February 17, 2019 Report Share Posted February 17, 2019 Change your trans fluid. I will start there first. Drain and fill. Don't flush. Drive a few miles drain and fill again. Toyota Type IV fluid. If that does not cure it, you have bigger problems. I had the same issue with my 2001 S60 and my 2003 Saab. That fixed it. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted February 18, 2019 Report Share Posted February 18, 2019 Transmission failure is pretty common in 01-02 Volvos with the 5spd auto. You could try changing the fluid, but be prepared for the worst. Link to comment Share on other sites More sharing options...
azatoglu Posted March 1, 2019 Report Share Posted March 1, 2019 I had a similar issue and my car is 2004 V70.When I bought the car it was in 144.000km.I changed the trans fluid with Mobil 3309 ATF and added a oil cooler with a filter.Now the car is in 197.000km and I changed the oil again.I think it cures the problem and prolongs the life of transmission.Maybe it will die eventually but I will be sucking 150.000km out of it at least.I used Transsaver transcooler part. Link to comment Share on other sites More sharing options...
MikeH Posted March 16, 2019 Report Share Posted March 16, 2019 you may want to change the b4 servo cap on the transmission. I just got a 2001 v70t5 2 weeks ago and it was flaring and huge bang into 3rd gear. Other gears abit iffy at times too. I did a drain/refill and changed the b4 servo cover tonight and the tranny on the test drive ran flawless. Waited a couple hours and it still drove flawless. The servo cover took me literally 5 minutes to swap out (after jacking and removing the wheel) I had version 1 on the car and the one i bought from the dealer was version 4. The part is cheap. 30usd or 40cad. Link to comment Share on other sites More sharing options...
