greenellie Posted February 25, 2019 Report Share Posted February 25, 2019 Hey all! I'm planning on swapping in 'white' 350cc injectors, a 16T, and a '98 T5 ECU in my 1998 V70 GLT. Only issue is, I'm having serious trouble finding a T5 ECU! I need an automatic one... I've scoured Ebay and various other sites and they all seem to be non-turbo ECUs. I've found R and T5 upgrades online and they're all relatively expensive (150-200 bucks). Any help or advice would be greatly appreciated. Thanks, -Ellie Link to comment Share on other sites More sharing options...
gdog Posted February 26, 2019 Report Share Posted February 26, 2019 1 hour ago, greenellie said: Hey all! I'm planning on swapping in 'white' 350cc injectors, a 16T, and a '98 T5 ECU in my 1998 V70 GLT. Only issue is, I'm having serious trouble finding a T5 ECU! I need an automatic one... I've scoured Ebay and various other sites and they all seem to be non-turbo ECUs. I've found R and T5 upgrades online and they're all relatively expensive (150-200 bucks). Any help or advice would be greatly appreciated. Thanks, -Ellie You're planning on plug-and-play?! You know the T5 ecu is mapped for 8.5:1 compression ratio, but your GLT engine is 9.0:1, yes? You realize while that will give you more boost, knock (and therefore knock induced ignition retard) will come along with it? If that's what you want, how close is your nearest pic-n-pull? Found this one: https://www.picknpull.com/vehicle_details.aspx?VIN=YV1LS5347W1425876 The ecu out of that should be what you want; they usually get around $60 unless you go on discount day.. Link to comment Share on other sites More sharing options...
greenellie Posted February 26, 2019 Author Report Share Posted February 26, 2019 6 hours ago, gdog said: You're planning on plug-and-play?! You know the T5 ecu is mapped for 8.5:1 compression ratio, but your GLT engine is 9.0:1, yes? You realize while that will give you more boost, knock (and therefore knock induced ignition retard) will come along with it? If that's what you want, how close is your nearest pic-n-pull? Found this one: https://www.picknpull.com/vehicle_details.aspx?VIN=YV1LS5347W1425876 The ecu out of that should be what you want; they usually get around $60 unless you go on discount day.. Thanks a lot for pointing that out, I had no clue the engines use different compression ratios. I’ve read posts of people swapping the ecu, turbo, and injectors and running it successfully so I guess I thought it wouldn’t be too bad of an idea. Maybe I should suck it up and order a tune. Link to comment Share on other sites More sharing options...
gdog Posted February 27, 2019 Report Share Posted February 27, 2019 17 hours ago, greenellie said: Maybe I should suck it up and order a tune. Yup; that's what I'd recommend too.. http://vasttuning.com/ Link to comment Share on other sites More sharing options...
bmdubya1198 Posted March 1, 2019 Report Share Posted March 1, 2019 Lots of people use the T5 ECU in their GLTs along with the T5 injectors (white or blue) and a 15g/16t. It seems to be perfectly fine, but of course the best thing to do would be to get a tune. Vast is a great tuner for M4.4. Link to comment Share on other sites More sharing options...
BlackT5 Posted March 13, 2019 Report Share Posted March 13, 2019 You should be able to flash your 98 ECU with a T5 bin. Link to comment Share on other sites More sharing options...
