hav716559 Posted June 20, 2019 Report Share Posted June 20, 2019 Hello, does anyone have a write up on how to replace the alternator on a 2005 XC70? Otherwise, does anyone who has replaced it have any tips or tricks? Thank you! Link to comment Share on other sites More sharing options...
JimLev1 Posted June 21, 2019 Report Share Posted June 21, 2019 Disconnect the battery first! Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted June 21, 2019 Report Share Posted June 21, 2019 Disconnect battery. Remove drive belt. Remove cooling fan. Remove alternator bolt on drive belt side. Remove two lower alternator bolts (long) Loosen bottom two A/C compressor bolts. Remove battery cable and signal wire. Slide alternator out in front of intake manifold where cooling fan was. Install in reverse procedure. Link to comment Share on other sites More sharing options...
