Rocketeer Posted February 28, 2005 Report Share Posted February 28, 2005 OK, Swedish Mike got back to me and gave me the scoop.The 300/70 wg is on 19Ts (i.e. The Euro 99-00 blue V70R AWD has 19T and 265 hp).So you will not be able to get a 16T with the 300/70 wg direct from Mitsu. You would have to find just the 300/70 wg from a 19T and just swap it onto the 16T like the buy in the How2 did.I think I'm just going to stick with a plain jane 16T and roll with it. I doubt I'm going to have wastegate problems with just a chip...- Slater←Keep us updated. I'd like to find out how it goes and if it can hold pressure. You going with 1 bar? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted February 28, 2005 Report Share Posted February 28, 2005 Even if it cannot 30 dollar MBC and your back in bizKeep us updated. I'd like to find out how it goes and if it can hold pressure. You going with 1 bar?← Link to comment Share on other sites More sharing options...
turbobrick Posted February 28, 2005 Report Share Posted February 28, 2005 If I'm not mistaken I believe that most usdm 16T's had a 216/60 wastegate. I have seen them with 300/70 wg but those may have only been available overseas.←your are correct, i am chipped boosting 17psi on ECU and have swapped in my 16T's wastegate until i can mount up the 16T directly, it has the stronger wastegate labeled 216/60. the old 160 wastegate would actually bog my car to the point of too rich, i was only able to hold 10-12 to redline regardless, with the newer wastegate i do hold around 14-15 to redline and it pulls much harder, spike around 18 on shifts. i highly recommend finding a stronger wastegate, i've seen that ATPTurbo sells actuators that look like they may mount up, though i am unsure. has anyone tried that route ?? as i'd be interested in the outcome. Link to comment Share on other sites More sharing options...
