Slater Posted March 4, 2005 Report Share Posted March 4, 2005 I know the 95s had an EGR and the 96+ didn't, so that means running a 95 ECU on a 96+ car would throw a code.Has anyone done it the other way around? I don't see any reason why the 96+ ECU wouldn't work on a 95.The processor is faster and it retards timing before boost. The EGR system would just not function, but I don't se that as being a problem.Anyone know?- Slater Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted March 4, 2005 Report Share Posted March 4, 2005 96 ECU does work on the 95's just like the 95 ECU's work on the 96's. My buddy Ben is using my 96 850 Turbo Speedtuning ECU on his 95 850 Turbo, works perfectly fine :) Link to comment Share on other sites More sharing options...
jross Posted March 4, 2005 Report Share Posted March 4, 2005 Motronic 4.4 didn't come into play until 98, but I've heard reports of 4.4 ECMs showing up on MY97 cars. I think95-97 were 4.3? I know my 96 is. Link to comment Share on other sites More sharing options...
steve s Posted March 4, 2005 Report Share Posted March 4, 2005 possibly cel? nothing serious... Link to comment Share on other sites More sharing options...
EricF Posted March 4, 2005 Report Share Posted March 4, 2005 94-97 are Motronic 4.3.The 94-95 had an EGR valve, and using a 96+ ECU will throw a CEL for it AFAIK...As for the Motronic 4.4 in the 98 cars, I think the only difference is that they have a barometric pressure sensor value? I'm not totally sure though, or to what extent (if any) it affects the fuel trimming or ignition timing. Link to comment Share on other sites More sharing options...
Slater Posted March 4, 2005 Author Report Share Posted March 4, 2005 94-97 are Motronic 4.3.The 94-95 had an EGR valve, and using a 96+ ECU will throw a CEL for it AFAIK...As for the Motronic 4.4 in the 98 cars, I think the only difference is that they have a barometric pressure sensor value? I'm not totally sure though, or to what extent (if any) it affects the fuel trimming or ignition timing.←Are you sure the 96+ ECU will throw a code for a sensor it doesn't even know exists? Usually it's the other way around. I know trying a 94-95 ECU on a 96+ car will throw a code because it's looking for an EGR system that doesn't exist> but the other way around shouldn't matter I would think... Link to comment Share on other sites More sharing options...
FIORE Posted March 5, 2005 Report Share Posted March 5, 2005 I'm not a 100% sure but I bought a used ECU from a 850 turbo i think it was a 95 could of been a 96. I had this ECU chipped by UPsolute and kept my stock 97 ECU. I havent experienced any problems with check engine lights. Link to comment Share on other sites More sharing options...
