DAZ-13B Posted December 29, 2009 Author Report Share Posted December 29, 2009 Thanks again fellasI'm going to get the head tested and reassembled first up,if thats cactus I may aswell look around for a T5 engine as the chances of finding another R at the wreckers in Australia is fairly slim ,does the T5 and the R engine share the same compression ratio ? I will then send the 18T off for a once over and reassembly.Next step I guess is to start ordering all of the necessary gaskets,head bolts,exhaust studs and nuts,water pump, cam belt,serpentine belt,idlers and tensioners from IPD.Pics to follow soon ! Link to comment Share on other sites More sharing options...
Chilled man Posted December 29, 2009 Report Share Posted December 29, 2009 Thanks again fellasI'm going to get the head tested and reassembled first up,if thats cactus I may aswell look around for a T5 engine as the chances of finding another R at the wreckers in Australia is fairly slim ,does the T5 and the R engine share the same compression ratio ? I will then send the 18T off for a once over and reassembly.Next step I guess is to start ordering all of the necessary gaskets,head bolts,exhaust studs and nuts,water pump, cam belt,serpentine belt,idlers and tensioners from IPD.Pics to follow soon !Any turbo motor from 94-98 will be the same motor - the T5 and R the GLT will be a LPT but will work just as well . Link to comment Share on other sites More sharing options...
DAZ-13B Posted December 30, 2009 Author Report Share Posted December 30, 2009 Any turbo motor from 94-98 will be the same motor - the T5 and R the GLT will be a LPT but will work just as well .Hmmm If things get desparate I thought about going for the 2.4T badged here in Aus (LPT), but I wasn't sure if manifolds , gearboxes and engine mounts would bolt up to the block. Link to comment Share on other sites More sharing options...
Chilled man Posted December 30, 2009 Report Share Posted December 30, 2009 Hmmm If things get desparate I thought about going for the 2.4T badged here in Aus (LPT), but I wasn't sure if manifolds , gearboxes and engine mounts would bolt up to the block.All the same . Figure the 2.3 the 2.4 and the 2.5 are all the exact same motor minus displacement , rods and pistions but will bolt up to any m56 , m66 , m59 , m58 and the autotragicrap . Link to comment Share on other sites More sharing options...
DAZ-13B Posted December 30, 2009 Author Report Share Posted December 30, 2009 All the same . Figure the 2.3 the 2.4 and the 2.5 are all the exact same motor minus displacement , rods and pistions but will bolt up to any m56 , m66 , m59 , m58 and the autotragicrap .Did I mention she's a manual..... Here are some pics as promissed and my wife really didn't mind me putting all of those parts in the cinema room for happy snaps...my garage is pretty full of Mazda RX-7 parts and the R.Yes I have some work to do...Head removed by previous owner...not sure why at this stage...Left hand side of engine bay...Right hand side of engine bay...Engine code on timing belt cover...A view from the rear...a little paint required...Look its right hand drive and the all important manual stick Funny place for a horn Top mounting looks good..just sitting there for the photo...Very bad water hose...may have contributed to the failure...We had a dust storm a few weeks back got into everything !Found this in the engine bay, not sure what its for or if its even off the car...Inlet with white injectors...Hows my head look ?Not sure why they took this apart, I cant see any damage, sorry about blurry pic..Cams...n stuffSomething to do with cams...I think I will take these along to the machine shop along with the cams,new cam seals,bolts,special sealant and lifters.Air box bits...Exhaust manifold and split turbo, I'm thinking they split it to get it out..dam it Oh well just send it off and get it rebuilt..18T in bits...With separate TPS this has to be a better throttle body than the 2000 my ?Intercooler pipe work...not sure if any of it is missing yet...Cams...Another view of the head...Valves...also can anybody see any problems here ?Lifters (HLA's) should I get new ones ?Hmmm I think im missing something, possible air flow meter ?Thanks for lookingIll start cleaning the years of dirt from the engine bay on the weekend, good new years day job Regards Daz Link to comment Share on other sites More sharing options...
EVL WAGN Posted December 30, 2009 Report Share Posted December 30, 2009 That threaded rod that your not sure of looks to be the wastegate actuator rod. Link to comment Share on other sites More sharing options...
Stormtrooper1 Posted December 30, 2009 Report Share Posted December 30, 2009 Great Find! Hope your able to get it up and running again! Link to comment Share on other sites More sharing options...
VTV70R Posted December 31, 2009 Report Share Posted December 31, 2009 That threaded rod that your not sure of looks to be the wastegate actuator rod.No it's not. It's a bracket that bolts to the valve cover (2 holes/bolts to the valve cover) and the top engine mount. The threaded end goes through a hole on the top engine mount bracket. Look at the closeup of the top engine mount bracket. There is a large hole, then a smaller hole underneath. The threaded part goes in that hole. Link to comment Share on other sites More sharing options...
Chilled man Posted December 31, 2009 Report Share Posted December 31, 2009 thats not a water hose thats the break booster hose it goes to the intake manifold at the throtal itself. and the only upgrade you can do to the throtal is to find a NonTurbo one there a bit bigger. Link to comment Share on other sites More sharing options...
DAZ-13B Posted December 31, 2009 Author Report Share Posted December 31, 2009 Thanks ! you guys rock !!Daz Link to comment Share on other sites More sharing options...
Chilled man Posted December 31, 2009 Report Share Posted December 31, 2009 no prob and it looks like a bad headgasket for as white as some of those exhuast valves are ... Link to comment Share on other sites More sharing options...
EVL WAGN Posted December 31, 2009 Report Share Posted December 31, 2009 No it's not. It's a bracket that bolts to the valve cover (2 holes/bolts to the valve cover) and the top engine mount. The threaded end goes through a hole on the top engine mount bracket. Look at the closeup of the top engine mount bracket. There is a large hole, then a smaller hole underneath. The threaded part goes in that hole.lololol....I need to pay better attention...lol Link to comment Share on other sites More sharing options...
DAZ-13B Posted January 1, 2010 Author Report Share Posted January 1, 2010 no prob and it looks like a bad headgasket for as white as some of those exhuast valves are ...Hi thereWhat would cause a bad head gasket on an unmodified car like this ? do they have any inheritant faults or could it just be lack of servicing of cooling system ect ?Just wanted to know as I would like to address any known issues with the rebuild.PS Chilled Man whats your name ?Regards Darrin (but my friends just call me Daz !)Great Find! Hope your able to get it up and running again!Thanks mateyProbably the only real problem here in Australia is finding parts,I would expect there would only be a hundred of these imported originally...?I have found a 2.4T in Melbourne but that car is 900 klms away ! So I will just have to play the waiting game and just see what comes up.Regards Daz Link to comment Share on other sites More sharing options...
Chilled man Posted January 1, 2010 Report Share Posted January 1, 2010 Hi thereWhat would cause a bad head gasket on an unmodified car like this ? do they have any inheritant faults or could it just be lack of servicing of cooling system ect ?Just wanted to know as I would like to address any known issues with the rebuild.PS Chilled Man whats your name ?Regards Darrin (but my friends just call me Daz !)Thermostat, Broken Coolant hose , ETC sensor , crack in rad , broken coolant tank those would be the inherent coolant system faults wich I have seen in a few cars already oh and its justin Link to comment Share on other sites More sharing options...
DAZ-13B Posted January 2, 2010 Author Report Share Posted January 2, 2010 Thermostat, Broken Coolant hose , ETC sensor , crack in rad , broken coolant tank those would be the inherent coolant system faults wich I have seen in a few cars already oh and its justin Ok cool as JustinJust as long as there are no head to block issues....I'm opting for the 04 R head gasket too, looks to be the one to use.PS Happy New Year everyone Regards Daz Link to comment Share on other sites More sharing options...
