S60 R Posted July 28, 2006 Report Share Posted July 28, 2006 Heres the order I went with, all Evolve products;1- Blue upper engine mount bushing2- Dp and advanced exhaust3- At all four corners rotors, pads, steel braided brake linesDepending on when Evolve comes out with the air intake system, either the ECU or air intake next. Link to comment Share on other sites More sharing options...
Tantrum Posted July 28, 2006 Author Report Share Posted July 28, 2006 Heres the order I went with, all Evolve products;1- Blue upper engine mount bushing2- Dp and advanced exhaust3- At all four corners rotors, pads, steel braided brake linesDepending on when Evolve comes out with the air intake system, either the ECU or air intake next.What do you think of the upper engine mount? Has it made any difference that you can feel?And what about the brakes? I'm especially interested in the SS brake lines. Noticable improvement in pedal feel under hard braking? Link to comment Share on other sites More sharing options...
S60 R Posted July 28, 2006 Report Share Posted July 28, 2006 The upper engine mount is def worth it, especially with the manual tranny. Shifting is more precise, and throttle response is quicker. Doesnt set the world on fire, but def noticeable.As for the brakes, the pedal feel is a little firmer and they do haul u down quicker. What I noticed (almost more so than the better braking performance) was the suspension, especially in advanced mode. The rotors are something like 5 pounds lighter each. In advanced, the suspension lost alot of the choppiness over bumps in the road, rebounding better. I hope that makes sense... Link to comment Share on other sites More sharing options...
Tantrum Posted July 28, 2006 Author Report Share Posted July 28, 2006 The upper engine mount is def worth it, especially with the manual tranny. Shifting is more precise, and throttle response is quicker. Doesnt set the world on fire, but def noticeable.I'll look into this. Was it easy to install or did you have the dealer install?As for the brakes, the pedal feel is a little firmer and they do haul u down quicker. What I noticed (almost more so than the better braking performance) was the suspension, especially in advanced mode. The rotors are something like 5 pounds lighter each. In advanced, the suspension lost alot of the choppiness over bumps in the road, rebounding better. I hope that makes sense...It does make sense. Eliminating 5 lbs of rotating weight is good. Link to comment Share on other sites More sharing options...
S60 R Posted July 29, 2006 Report Share Posted July 29, 2006 I'll look into this. Was it easy to install or did you have the dealer install?Did it myself. Was a PITA getting the old one out, but was easy after that. Link to comment Share on other sites More sharing options...
Tantrum Posted July 31, 2006 Author Report Share Posted July 31, 2006 Did it myself. Was a PITA getting the old one out, but was easy after that.Any special tools needed? Thanks for the info. Link to comment Share on other sites More sharing options...
S60 R Posted August 2, 2006 Report Share Posted August 2, 2006 Any special tools needed? Thanks for the info.A screwdriver, hammer, pliers, and alot of patience if the old one is still good And two socket wrenches (or regular adjustable should work).Here's a link to some pics...http://www.volvo-forums.com/2005-Volvo-S60..._item-cid55.htm Link to comment Share on other sites More sharing options...
Tantrum Posted August 2, 2006 Author Report Share Posted August 2, 2006 A screwdriver, hammer, pliers, and alot of patience if the old one is still good And two socket wrenches (or regular adjustable should work).Here's a link to some pics...http://www.volvo-forums.com/2005-Volvo-S60..._item-cid55.htmThanks for the info. Link to comment Share on other sites More sharing options...
