lookforjoe Posted May 3, 2011 Author Report Share Posted May 3, 2011 Thanks, guys.I'll be dyno'ing it @ Carlisle. Have to get my son at some point to shoot some video, he doesn't have much time, with college work right now, but soon, I hope.Yes, I used Volvo sealer. I know you can use generic, but I feel better using the Volvo-packaged product. Link to comment Share on other sites More sharing options...
lookforjoe Posted May 9, 2011 Author Report Share Posted May 9, 2011 Finished the COP install, after a minor glitch with the cam sensor timing that caused a over rich condition...all covers back in placebut... while sitting idling @ Home Depot.... I heard a rattle & the motor died. Cranking it over, sounded like a tin can up top. Had it towed home, and removed all the plugs. I could see one #1 intake valve in the spark plug hole!!!!Pulled the head again today, one of the new intake valves snapped just below the keepers...hit piston againhope the valve seat & guide ain't buggered. Link to comment Share on other sites More sharing options...
thomasw Posted May 9, 2011 Report Share Posted May 9, 2011 So this time not a cam timing issue but simply a valve failure of some sort? I'll give you points for persistence man. Is this a common thing by the way as I've never come across it before myself. Link to comment Share on other sites More sharing options...
lookforjoe Posted May 9, 2011 Author Report Share Posted May 9, 2011 So this time not a cam timing issue but simply a valve failure of some sort? I'll give you points for persistence man. Is this a common thing by the way as I've never come across it before myself.Correct - not cam timing. It's not due to binding, either - which was brought up as a possibility - the Enem cams are designed to run with stock springs up to 8500rpm w/o issue. Link to comment Share on other sites More sharing options...
DAZ-13B Posted May 10, 2011 Report Share Posted May 10, 2011 Are you putting new head gaskets on every time you do this ?Reason I ask is I have a head gasket that's been on a head for about a week then I stuffed my bottom end, got another project now...I would like to use the good head and the gasket on my 850R !The gasket looks the same as yours with that red coating on it..Regards Daz Link to comment Share on other sites More sharing options...
lookforjoe Posted May 11, 2011 Author Report Share Posted May 11, 2011 Are you putting new head gaskets on every time you do this ?Reason I ask is I have a head gasket that's been on a head for about a week then I stuffed my bottom end, got another project now...I would like to use the good head and the gasket on my 850R !The gasket looks the same as yours with that red coating on it..Regards DazNew head gasket, new head bolts. I would never reuse either. I've had head bolts snap trying to reuse, never again. I reused the intake & exhaust gaskets on the first removal, but that was only 'cos the car literally ran 1 mile. This time I'm changing the cam seals & manifold gaskets again, it's just not worth the aggravation if it leaks.Worked on cleaning up the piston's high spots while I'm in wait mode for the head. numbers 2-4 look pretty much the same..number one... not much I can except make sure there are no high spot/sharp edges that will cause detonation Link to comment Share on other sites More sharing options...
Rabin Posted May 11, 2011 Report Share Posted May 11, 2011 Wow... I really admire how these set backs don't seem to deter you much at all... (IE No swearing in the posts or anything!) I even followed your build link and read it beginning to end, really amazing work. I can't wait to see what the numbers are once you get it all buttoned up with the teething issues behind you.Rabin Link to comment Share on other sites More sharing options...
DAZ-13B Posted May 12, 2011 Report Share Posted May 12, 2011 Yeah thought that may be the case Are you using genuine or aftermarket bolts, head gaskets and seals ?Volvo Australia want $160 trade price for a set of head bolts and $120.00 for the head gasket.More drama's with my car...I'll post it in my thread.... Link to comment Share on other sites More sharing options...
lookforjoe Posted May 13, 2011 Author Report Share Posted May 13, 2011 Yeah thought that may be the case Are you using genuine or aftermarket bolts, head gaskets and seals ?Volvo Australia want $160 trade price for a set of head bolts and $120.00 for the head gasket.More drama's with my car...I'll post it in my thread....FEBI bolts, Victor Reinz head gasket, Elring t/stat housing & water pipe gaskets, Volvo packaged seals, intake & exhaust gaskets.Wholesale on the bolts about $3 ea, head gasket $45 Link to comment Share on other sites More sharing options...
lookforjoe Posted May 17, 2011 Author Report Share Posted May 17, 2011 Bay with no more distributor/wires Link to comment Share on other sites More sharing options...
lookforjoe Posted May 22, 2011 Author Report Share Posted May 22, 2011 New numbers with the head/cams18psi 1st pull, 22psi 2nd pullNow I need to refine it. Link to comment Share on other sites More sharing options...
thomasw Posted May 23, 2011 Report Share Posted May 23, 2011 Outstanding Link to comment Share on other sites More sharing options...
lookforjoe Posted August 11, 2011 Author Report Share Posted August 11, 2011 Next up is a Nathininwa Intake built to my specificationand an LGSpeed headerand a new DP to go with it - will have lined flex couplings on both pipes to allow for header expansion, as per Lars's instructions. Link to comment Share on other sites More sharing options...
Tzantushka1568908311 Posted August 11, 2011 Report Share Posted August 11, 2011 Link to comment Share on other sites More sharing options...
lookforjoe Posted August 19, 2011 Author Report Share Posted August 19, 2011 Had to rethink the DP - no room for the 'screamer' pipe W/AWDclearance issuesI'll be moving the FPR & housingO2 bungs & fitment around driveshaftback in the basement Link to comment Share on other sites More sharing options...
