03 Dual VVT head With Enem Cam Install
lookforjoe
  • Replies 92
Eeeeek. You removed the CAMS!!! Hope you have your fitment regime' fully documented ;)
Hats off to you sir for doing what you do
Thanks! I'm NEVER moving those cams, my sphincter still gets tight just thinking about all that :lol:
Mine puckered in sympathy when I saw them missing in the head shot above :unsure:
That's my old 2.4L LPT motor - I keep it in the basement so I can mock up things like this - I had no intention of removing my engine just to do a header install!
No, it's much, much better with the heat shield. Most of the radiant heat came from the collector, rather than right off the runners, so this has made a substantial difference.
After a hard run, temps on the 'cool' side of the shield are in the low 200's - much better than the 600-800 radiating off the runners & collector at idle beforehand.
My only remaining concern is the brake line that crosses the firewall. You can see in the 1st pic that I used a stainless flex hose over it, just to create somewhat of an air gap - I've ordered some "Heat Sheath" to further isolate that center section of line.
can't edit my post -forgot to add this short video of the exhaust note - this is pre header & custom intake, beginning of Aug.
  • 2 weeks later...
No, no time at the moment, back to regular work schedule now. Dyno won't be until next spring. Between now & then I will work on refining the setup.
I'll try to get my son to shot some footage, I know it sounds nuts from inside @ 8200rpm, can only imagine what it sounds like from outside.
Forgot to add, I did the heat sheath on both the firewall brake line, and the fuel lines up the back of the motor...
fabricated a revised ECU cooling duct, since that has been unused since I went FMIC
filtered inlet
and installed my dual boost gauge - registers intake boost (red needle) and exhaust back pressure (green needle)
crappy vid
no can embed anymore????
Another crappy dual boost gauge vid - hard to drive & shoot
<object width="640" height="390"><param name="movie" value="
name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></embed></object>
also stripped the black coating from my hotside intercooler piping, got to reduce heat soak potential wherever possible
That didn't work very well...
